Brake options needed for 73 project
At this point the car needs everything, but first of all it needs brakes. (It was a thrill trying to get the car up on a car trailer with an engine that barely ran and essentially no brakes
)The other thing is that I am on a budget. (I know, a budget vette is a ridiculous concept. This is my 7th Vette, so I know that all too well)
The first order of business is to get the car to stop. I am assuming I am going to need to replace all four calipers and rotors.
My question is, what do I replace them with? Stock? What upgrades are available and are they worth it performance wise?
Recently I read an article where they upgraded the brakes of an early 70's Jaguar XKE. They tested the stopping after each mod. For them, the best bang for the buck was getting the stock system in excellent condition. The aftermarket brakes did inprove the stopping power, but not very much, especially in comparison to how much the aftermarket brakes cost.
Any suggestions?
Glenn in San Diego
If you really want to go low buck just rebuild the calipers yourself. New seals are about $10 a caliper and a brake hone is probably $15 or 20. I would disassemble the calipers and determine if they are stainless steel sleeved. Don't bother rebuilding non sleeved calipers because the bores will probably be pitted beyond repair. Get some aggressive pads like hawk HP plus and turn the rotors, check the runout and you should be good.
Rick B.
Corvettes were way ahead of their time as far as bracking systems go.
Someone mentioned "O" ring calipers, I agree that they are the cats meow.
SS sleeved OEM calipers-hopefully yours are already SS sleeved
VBP Oring pistons -get them as a conversion kit for ~$150 for all 4 calipers
Braided stainless flex lines
Hydroboost power assist preferred -Its on my list
OEM rotors and high quality Ceramic pads
Slotted rotors and Hawk pads if your feeling rich.
Brent......
