BB fans...
Old Feb 7, 2008 | 11:50 PM
jerrylee's Avatar
jerrylee
Default BB fans...
Can u guys tell me which electric fans u are running to cool down them BB's.....I'm still having a slight cooling problem and I think I need more cfm's... Presently I'm using Flex-a-lite's #210....As u guys know it's very tuff finding room in the C-3's......Thanx...Jerrylee///
Old Feb 8, 2008 | 06:14 AM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I am having the radiator-fan package from Dewitt, the fans are a dual 11 in. Spals. the difference between stock and now is more than between day and night!! .. dropped the temp from 210 with A/C off to a 200 with A/C on, and thats in a 90F days, in a 100F+ days, I even wont think of starting the BB at all, and I can easily maintain a 200F all day long and about 210F with A/C on.
Old Feb 8, 2008 | 07:32 AM
Durango_Boy's Avatar
Durango_Boy
For a single fan on a budget, get a MarkVIII or Taurus fan, and a controller of some kind. If you want dual fans, get a Focus fan, and if you have the budget, get a dual SPAL fan set from DeWitt.
I was planning the Taurus fan, but decided I wanted dual fans. I went with the Focus set, and love it.
Old Feb 8, 2008 | 08:12 AM
BB72's Avatar
BB72
Default Your brother
I have a Mark 8 fan for $50 plus shipping. I can ship it from the US side this month if your interested. Actually I'll be right down where you live, we're going to Stamford first and then NYC.
Old Feb 8, 2008 | 08:13 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I assure you that big blocks from the factory did not have overheating problems. If you are overheating with basically stock equipment, something is not functioning properly. Just my 2 cents.
Old Feb 8, 2008 | 08:47 AM
rihwoods's Avatar
rihwoods
What are your temps for highway/traffic..??
Old Feb 8, 2008 | 09:22 AM
capevettes's Avatar
capevettes
CF Community Team
Active Streak: 90 Days
2016 C2 of Year
2015 C3 of Year Finalist
I agree. I'm running a stock radiator and clutch fan in my stock 427/390 and have no overheating problems. Unless you are running something radical I would go back to basics before you get heroic with electric fans and all. You may only be masking the underlying problem.
Old Feb 8, 2008 | 09:29 AM
Ironcross's Avatar
Ironcross
This said it all,.......
Old Feb 8, 2008 | 10:27 AM
BB68Vett's Avatar
BB68Vett
I am not sure this is entirely true. I can recall reading articles and other threads (on and off this forum) that indicated that there were warranty issues back in the day with the big blocks overheating. This was one of the reasons that cut outs were made underneath the front of the car to allow more airflow over the radiator.
Keep in mind, I am not saying that a properly functioning stock cooling system doesn't work, but in stop and go traffic on a hot summer day, even the stock system is challenged and may not be able to keep up.
However, if the engine is overheating on the highway, then I agree cooling fans are not the answer and there is some other problem that needs to be resolved. Could be a slipping belt, collapsing lower radiator hose, improperly working thermostat, corrosion inside the radiator, inadequate airflow over the radiator, a malfunctioning radiator cap, a bad water pump etc.
Old Feb 8, 2008 | 10:43 AM
bashcraft's Avatar
bashcraft
I have a '69 which was originally a small block car. My 454 with ~450 hp never has gone above 180f, with the stock clutch fan and the small block radiator. So I would say that if the stock system is in proper working condition, it's not at all challenged.
Old Feb 8, 2008 | 11:58 AM
rihwoods's Avatar
rihwoods
69 502...4 row C/B...stock 5 blade/thermo clutch....180 stat...
Running in 100 degree ambient air:
Highway....coolant temps 195 or so...
Stop/go traffic....coolant temps 200-205 F (Max)
Rich
Old Feb 8, 2008 | 12:24 PM
Jud Chapin's Avatar
Jud Chapin
I had a '67 427 with a/c (should never have sold it but that is another story), live in S. Florida and never had a problem. I know they have the reputation of running hot but I never met anyone that had one that had an overheating problem unless there was something wrong.
Old Feb 8, 2008 | 12:52 PM
roscobbc's Avatar
roscobbc
I am dubious that the dual fan set-up guys seem to using actually gives any advantage over the stock early BB set-up If the stock unit is in proper working order. Sure the engine runs hot - we cook inside the car - but is it actually overheating?
I have a buddy who went through all this and installed the dual fan set-up in a '73 BB car and all it really did was to stabilise the temperature - not make it any cooler Perhaps what is really need is more attention to condition of the radiator and sealing of it within front compartment
Old Feb 8, 2008 | 01:25 PM
BB72's Avatar
BB72
The rad is a heat exchanger, the better condition/quality it is the more efficient it is. For those that don't want a fan shroud, the electric route is the only way to go. If you want to keep it stock I would suggest you bring the rad in for checking, make sure all your seals are good between the rad and cradle and rad to shroud. Make sure the shop doesn't paint the rad with heavy paint, that just decreases the efficiency of the heat exchange. There's suppose to be a seal on top of the rad cradle also. I think you said you had a flex fan, is it close to the size of the shroud opening? Is there any obstructions as far as air getting to the rad? Are any of your hoses collapsed ? Do you have an air lock somewhere in the motor, is your thermostat good or low enough? And a major one...is your timing right? That can make it run very hot. Just my .02
Old Feb 8, 2008 | 02:39 PM
Ironcross's Avatar
Ironcross
Default Stock System
I guess words are not adequate for non-believers. Below is a one owner L88 powered 1968 coupe with 28,000+ miles of hard use with zero heating problems from day one with a original factory stock cooling system. I can also produce several other high HP BB street driven vehicles all with zero issues and they too have factory stock cooling systems. So the arguments of overheating is just opinions with out actual first hand knowledge from new cars. I`m sure I am not the only one as I would never be so fortunate. With my luck if it would have overheating issues, it would have to belong to me,..
Old Feb 8, 2008 | 02:55 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
I've run some very healthy BB's in traffic in hot weather over the years w/o trouble or w/o such which couldn't be readily solved.
Your problem could be anything from among some of those already mentioned to (forgive me if I duplicate any) simply lacking a good seal around the rad or a faulty stat to insufficient timing advance or mal-adjusted carb A/F mix (always check the ignition first), to bearings put up too tight, a bad rad core, or to an undersized cooling capacity. Note that the last one usually only becomes an issue with substantially hopped up mills it everything else is in order. Also, excessive oil pressures can aggravate the situation.
Old Feb 8, 2008 | 03:09 PM
Gordonm's Avatar
Gordonm
Oh No. You are all wrong. That was an option box that got checked. The overheating BB option. With AC it was a mandatory option.
I agree go back to the basics and get the problem solved before trying to mask it with electric fans.
To BB fans...
Old Feb 8, 2008 | 03:29 PM
Jud Chapin's Avatar
Jud Chapin
Oh, that's right. I almost forgot about that option.
Old Feb 8, 2008 | 05:15 PM
HamadUP's Avatar
HamadUP
St. Jude Donor '08
I cant believe the stock cooling system of a BB with A/C will be sufficient in a hot 95-100F day at all. When I had my stock cooling system, it was really battling to keep the engine below 210F and the A/C was off all the time, I wouldn't dare to switch it on at all!
Old Feb 8, 2008 | 07:08 PM
jerrylee's Avatar
jerrylee
Right now my temps are ok hanging around the 190/200 mark..It's just that about an hour into the ride they gradually climb up pushing close to 220....Plus the temps are only in the 40's outside..The warm weather didn't even get here yet.....
