Trailing Arm Bolt
Old Feb 8, 2008 | 07:41 PM
Coconut's Avatar
Coconut
Default Trailing Arm Bolt
Is there a special way (or a special tool needed) to remove the main long bolt that goes through the frame & the bushings in the eye of the front of the trailing arms on a 1982 Corvette? I've removed everything from my trailing arm assembly (including the front shims), but can't seem to be able to get the front bolt out.
Old Feb 8, 2008 | 08:01 PM
A88FXRS's Avatar
A88FXRS
Bolt Is Probably Rusted Inside Bushing. If You Cannot Turn It With A Wrench, Firewrench Is Next. Good Luck !!
CUT BOLT IN THE AREA WHERE THE SHIMS WERE. WILL TAKE 20 SECONDS EACH SIDE AND YOU ARE FINISHED.
Old Feb 8, 2008 | 08:15 PM
'75's Avatar
'75
That bolt usually rusts into the bushing, but most use a sawzall with a bimetal blade to cut the bolt right next to the trailing arm on both sides of it.
Scott Marzahl's Avatar
Scott Marzahl
If the bolt is rusted onto the inner sleeve of the bushing which is typical, the easiest way to remove it is with a sawzal. Get a couple of 8" carbide blades and in less than an hour you'll be done. Search the archives, its the fastest way to do it.
Old Feb 8, 2008 | 08:57 PM
rponfick's Avatar
rponfick
I assume you are not saying the head of the bolt is facing outward and nut on the inside, and there is not enough space to slide the long bolt out. That means someone installed it backwards on a frameoff job.
Ralph.
Old Feb 8, 2008 | 09:08 PM
Gordonm's Avatar
Gordonm
Do not use a carbide blade. Get yourself some good bimetal blades. Preferably Lenox blades, seeing I work for Lenox. 8 inch or 9 inch will work. You can even grind off a little of the tip if you need to shorten them up a little. With a good blade and a little cutting fluid you will be through the bolts in a few minutes.
Carbide tip blades will shatter the carbide with all the bouncing around. A carbide grit blade will work but will take a long time.
Old Feb 8, 2008 | 09:16 PM
Scott Marzahl
Thanks for catching that Gordon, I did use bimetal ones, not carbide
Old Feb 8, 2008 | 09:30 PM
gve's Avatar
gve
DO NOT use the torch on a fiberglass car, use the sawzall.
Old Feb 8, 2008 | 09:47 PM
ebertthebull's Avatar
ebertthebull
Default ta bolts
If you can get a piece of plate 1 inch or so thick and cut it in an L-shape about 12 by 6 inches. drill a 1/2 inch hole about 1/2 deep in the short end near the end.(the foot of the L) Now you have a tool that you can whack with a sledge. It worked for me and is a lot easier than using a sawzall.The hole goes over the end of the bolt and the other end sticks out past the body so you can whack away and not have to worry about damaging your body . Plus you can get a nice swing. Onece they get moving they come right out.
Old Feb 9, 2008 | 01:07 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Sawzall the ticket. Good luck!
Old Feb 9, 2008 | 01:21 PM
bj1k's Avatar
bj1k
I have a special tool that I made for my air chisel. I took an old chisel and cut it off blunt on the end, then ground an indentation right in the center of the end so it wouldn't slip off of the end of the bolt. It drives out the most rusted bolts with ease.
Old Feb 10, 2008 | 06:23 PM
I'm Batman's Avatar
I'm Batman
St. Jude Donor '07
8" bimetal blades on a Sawzall. I couldn't find the Lenox blades in 8" locally, but the ACE hardware had some yellow ones that worked fine. I think they had a DeWalt logo.
Old Feb 10, 2008 | 06:29 PM
Jeffery73's Avatar
Jeffery73
St. Jude Donor '08-'09-'10-'11-'12-'13
I used an air hammer. I used a bit that had a flat end. It took about 20 minutes of hammering on one side and about 30 seconds on the other side.
Old Feb 10, 2008 | 07:14 PM
ctgene's Avatar
ctgene
Banned Scam/Spammer
I just took my TA's off my '79 this past week...after taking out the shims, I soaked the area with PB solvent...after a couple of hours I took a punch and drove the bolt as far as I could...I then took a smaller diameter bolt, put it in the hole and used the punch again to knock the bolt out...took about 2-3 minutes on each side...installed my new VBP offset TA's today...
Old Feb 10, 2008 | 07:20 PM
Gordonm's Avatar
Gordonm
Oh your killing me here. We actually only make 6,9, and 12 inch blades. That is why I had to grind the pointy end down some. Any good bimetal blade will do the job. Dewalt is a mid grade blade. Should work fine.
Old Feb 10, 2008 | 08:14 PM
A88FXRS's Avatar
A88FXRS
CTGENE, Your Lucky Day. Obviously Your Bolts Were Not Frozen To The Bushing Sleeve. Good Job.
Old Feb 11, 2008 | 03:30 PM
Coconut's Avatar
Coconut
Default Seized
The bolt is obviously seized. After using a hammer, the bushings actually came out on one side. The bolt moved out about 1/4", so I'm going to use the bi-metal sawsall blade to cut it out. I'll then replace the polyurethane bushings that are in it. Thanks to all!
Old Feb 11, 2008 | 03:51 PM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
I broke off the threaded end on one side when removing my TA's. Removed the whole body, then used a grinder to remove the bolt head. And it still wouldn't knock out! I actually bent a big center punch trying to knock it out!
Ended up drilling the bolt from the outside of the frame, smashing the remaining part of the bolt through the outside hole and finally had enough clearence to pry the TA out.
They rust in place. Use a cutting blade on a grinder to cut through the bushing, then knock the ends out once you get the TA out. Silly design.
Go back with stainless steel parts.
Old Feb 11, 2008 | 05:40 PM
bj1k's Avatar
bj1k
Default Anti Seize compound
Since I didn't want to go through this again , I coated everything with anti seize compound before reassembly.
To Trailing Arm Bolt
