Quadra Question what is this carb from #
Old Feb 10, 2008 | 06:19 AM
RunningMan373's Avatar
RunningMan373
Default Quadra Question what is this carb from #
It's a rebuilt Quadrajet. # 7043202 FS 1933. thanks.
also, What is the screw, spring loaded, center, bottom plate, directly below the feul inlet?
Old Feb 10, 2008 | 06:38 AM
BigBlockk's Avatar
BigBlockk
It is from a '73 Small Block.
BigBlockk
Later.....
Old Feb 10, 2008 | 06:46 AM
RunningMan373
BigBlockk
Later.....
OK, the PO might have had the original rebuilt then. It may be useable.
Old Feb 10, 2008 | 07:43 AM
69small block's Avatar
69small block
Default carb
my info says 1973 auto trans chevy on the 193 day of 73 and i think in the flint plant
Old Feb 10, 2008 | 08:20 AM
jim2527's Avatar
jim2527
73 Chev /GMC/Truck 350
...A neat little link:
http://www.carburetion.com/Number/bynumber.asp
Old Feb 10, 2008 | 12:37 PM
BigBlockk's Avatar
BigBlockk
The Lars tech sheet saids it should have a 73/44 primary setup with DA secondary rods. This should be real close. You need to open it up and see what the combo is. The idle circuit may be a tad lean but it should do well.
BigBlockk
Later.....
To Quadra Question what is this carb from #
