1968 Time Build Code = J09 ?
Old Feb 10, 2008 | 11:56 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Default 1968 Time Build Code = J09 ?
What does J09 mean on the time build code area on the trim tag? Is this January 9, 1968?
Old Feb 10, 2008 | 12:15 PM
Mike Ward's Avatar
Mike Ward
The letters started with the first month of model year production, so in 1968 A is for August 1967. That makes J = May 1968.
May 09 is the date the trim tag was stamped and attached to the body. The car was completed a day or two later.
Old Feb 10, 2008 | 12:20 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Mike - the serial # I am looking at is 18800 out of 28566 which is about 65% through the model run. That means that they would have built 35% of the Corvettes that year from May 10th through July 15th. Does this sound right to you?
Old Feb 10, 2008 | 01:04 PM
Mike Ward's Avatar
Mike Ward
Production ended in August 1968, not July.
The last car built in April was 17676, the last in May was 20928 so your number makes sense.
To 1968 Time Build Code = J09 ?
