I took my intake manifold to a local shop to have it cleaned. They took off the little pan that is attatched to the bottom. It looks like it is attatched with rivets or pins. I think I found the correct pins but I am not sure. Here is a link to what I think are the correct fastners. Also what is the function of this pan and should I use it.
Those are the correct type of rivets to use. The pan is there to help reject heat [coming from the engine] from getting to the intake and incoming air/fuel mixture. If it were me, I would replace it after you get done painting it. If you paint the plate, too, it won't reject the heat as well as if bare.
save yourself the cost of shipping. When I needed new rivets after glass beading my manifold and had removed the pan I picked up the correct rivets at my local Chevy dealer's parts counter.
If I'm not mistaken, they were part #10229247 (but have the parts counter confirm that first). They ran $.63 each.
Actually, just the opposite.
The pan is to keep the heat of the crossover pipe in the manifold from cooking (and coking) the oil to the bottom of the manifold in the lifter valley.
If the General was worried about heat in the carb, do you think he would have put an exhaust crossover running right under it? Furthermore, if keeping heat out of the intake charge was the intent, don't you think that the cover would shield the manifold runners too and not just the center (where the crossover is)?
hmm...what happens if one of those vibrates loose and comes off?
Good question but the more I think about it, I don't think it's possible to do as when the cover is on, you don't have access to the other side. Again, I'm going on my memory which ain't as good as it used to be.
