Thoughts on this 383 build?
Old Feb 10, 2008 | 07:11 PM
column5's Avatar
column5
Default Thoughts on this 383 build?
Any thoughts on this build would be appreciated. I've acquired a late model 350 block (roller, 1-piece rear main) that I am going to build up into a 383. Cost is a concern, so all parts must offer best bang-for-buck.
Rotating assembly: Scat kit with cast crank, forged 6" rods with 7/16" ARP fasteners, forged Probe flat-top pistons
Cam: Comp 08-422-8 or Lunati 60112 (Desktop Dyno shows these two cams to be very similar, but I am not sure...)
Heads: Leaning towards Brodix IK210s (2.080 intake port, big flow, but my concern is going too large and killing the low end)
Intake: My existing Weiand 8004
Carb: 750cfm Q-Jet
DD estimates 500 ft-lbs @ 4500 rpm and 483hp @ 5500 rpm.
This will be mated to a TH400, probably with a ~2500 rpm torque converter. I have 3.08 gears but plan to go to ~3.55 sometime in the future (probably a project for next winter).
The engine is for street use only, and I don't care to wind it much over 5500 to 6000 rpm. I need something more visceral than the L48, though...
Anything you would do differently? Why? All advice is appreciated!
Old Feb 10, 2008 | 07:25 PM
Gordonm's Avatar
Gordonm
Not a bad build up but the HP and torque estimates are high for that motor with that cam. Should produce good torque down low with that combo. I would step up to a cam in the high 220 @ .050 range. Remember the cams are rated for a 350. A bigger motor will require more duration.
Old Feb 10, 2008 | 09:01 PM
column5's Avatar
column5
Thanks! The Lunati above is described as having 231/239 duration at 050...so that should be fairly good, right?
Cam selection is definitely the most frustrating part of this process...
Old Feb 10, 2008 | 09:10 PM
Gordonm's Avatar
Gordonm
I like that one better. Even after you decide and it is in the car and running you will think, what if I run this cam or that cam.
Old Feb 10, 2008 | 09:12 PM
Scott Marzahl's Avatar
Scott Marzahl
I think the IK210s have been discussed before as having too large of an intake port to match a conventional manifold. Brodix wants you to buy one of their intakes.
The IK180s are rated for a mild 383 build. You don't mention a compression ratio target and I assume you have headers and a good exhaust system.
Old Feb 10, 2008 | 09:15 PM
column5's Avatar
column5
Rgr that, I was concerned about the 210s. I may look at their manifolds, but the IK180s have great flow numbers and are considerably less expensive.
Compression ratio will be approximately 10.5:1, and I will be adding headers and 2.5" exhaust with Magnaflows. I am considering the kit from Corvette America.
Old Feb 10, 2008 | 09:44 PM
LFZ's Avatar
LFZ
I have a comp cams 236/242 roller with a 112lsa...very tame, but is a monster when you step on the gas, and i don't take it past 6000rpms. The streetablity is in the wide lsa.
Old Feb 10, 2008 | 10:49 PM
OzzyTom's Avatar
OzzyTom
112 lsa gives very good torque spread on my 242/240 @ 0.050 hydraulic roller. 383 cubes gives plenty of grunt down low, and if you run a good stall converter with 3.55 diff gears, you'll need to keep a toothbrush in the car to get the bugs out of your grinning smile
Old Feb 11, 2008 | 09:35 AM
jackson's Avatar
jackson
Y'all need to check this because I'm doing this from memory only ...
I think the IK210 is a different animal ... it's alot lot more $ than either IK180 or IK200 ... I think it's cnc'd ... I think IK210 actually has a smaller intake PORT GASKET dimension than IK200 ... I know counterintuitive but I think so ... check it.
seems IK200 makes big flow numbers from a huge port volume alone ... seems IK210 makes good flow numbers from a different port shape/valve size & not just volume.
Most intakes that PROPERLY fit big-gasket (?fp1206) IK200 may not fit under C3 hood ... seems IK180 & IK210 have a few more options. Off top of my head ... y'all check it.
-edit-I checked, gasket apps verified from brodix site:
• Intake Gaskets:
FEL-PRO 1204, COMETIC C5416 (IK 180)
FEL-PRO 1206, COMETIC C5414 (IK 200)
FEL-PRO 1205 (KC IK 210)
To Thoughts on this 383 build?
