I run 17X8 with 4 inch backspacing and 255 45 17s on the front. The rears are 18X10s with a 5.5 backspace and 275 40 18s all on stock trailing arms. 17 and 18 inch you do not need offset arms as the spring is inside the wheel diameter and the trailing arm at that point is in far enough notto rub.
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
I don't know about the fronts because I have 17ls on mine. But the rears will fit without removing the e brake bracket because the wheel clears that bracket, at least it did on mine
Called VBP today and talked to Gary and he gave me the go ahead. Said that the only issue might be the parking brake bracket, but he doesn't even think that'll be an issue.
May be a month or so, but I'll post some pictures once I get them.
