Is CE Stamping Valuable?
Old Feb 11, 2008 | 11:32 PM
lr172's Avatar
lr172
Default Is CE Stamping Valuable?
I am having my '69 3512 block bored and decked this week. Is there any inherent value in having the stamp intact if it is a CE block? I figured there is a date stamp and that is about the only meaningful piece of information other than where it was cast.
I want to get my quench closer to .040 and can't get there without decking.
Old Feb 12, 2008 | 07:36 AM
markdtn's Avatar
markdtn
If it isn't original engine to the car, the stamping is not worth keeping IMHO. (Unless it is a valuable block from some other car that the owner might want matching numbers)
Old Feb 12, 2008 | 07:51 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
I wouldn't shave any numbers off until you know what you have. Just my 2 cents.
Old Feb 12, 2008 | 09:07 AM
moosie982's Avatar
moosie982
Doesnt "CE" designate it as a short block that came in a crate, usually sold over the parts counter, if the motor was replaced @ the dealers service shop they would somtimes stamp them with the appropriate #s to that vehicle. ????? Peace, Moosie
Old Feb 12, 2008 | 11:33 AM
Roughrider's Avatar
Roughrider
CE = Chevrolet Engine
It's either a warranty replacement engine or sold over the counter engine. It's not original to the car. Nothing special about it but I wouldn't remove any numbers if at all possible. If you deck it, you can always have it restamped so the original codes are not lost. It's not like you're trying to pass it off as something it's not. You just want to preserve its origin.
Old Feb 12, 2008 | 12:59 PM
Mike Ward's Avatar
Mike Ward
Old Feb 12, 2008 | 01:00 PM
Scott Marzahl's Avatar
Scott Marzahl
CE=Chevrolet Engine with a serial number to track the warranty replacement. I'd deck it as needed.
Old Feb 12, 2008 | 03:07 PM
lr172's Avatar
lr172
I figured it wasn't of special value. Just wanted to be sure that I wasn't detracting from the value of the block.
Old Feb 12, 2008 | 07:17 PM
Solid LT1's Avatar
Solid LT1
WRONG! NCRS accepts "CE" code as "numbers matching" and does'nt deduct judging points for a "CE" code motor.
Old Feb 12, 2008 | 08:20 PM
dmayhew's Avatar
dmayhew
I have heard that CE stands for counter exchange. And was used when the block or motor was replaced under warranty
David
Old Feb 12, 2008 | 08:44 PM
Mike Ward's Avatar
Mike Ward
Let's see some references for that please.
Old Feb 12, 2008 | 09:43 PM
Scott Marzahl
I do not see any reference for that in any of the judging manuals I have.
Old Feb 12, 2008 | 09:53 PM
7T1vette's Avatar
7T1vette
I would think you'd also need the original dealer invoice and/or warranty paperwork showing that the CE replacement actually replaced your original [defective] engine. Heck, you can find a lot of CE engines with the correct date codes. That doesn't mean it was intended or installed in your car by the dealer. If you couldn't prove that, what would "numbers matching" really mean?
Old Feb 12, 2008 | 10:15 PM
Mike Ward's Avatar
Mike Ward
There isn't any. Having a CE motor is PROOF that it cannot be the factory original engine.
Having a 'decked block' can always be argued that it is the original, but the stamps accidentally got machined off by someone who didn't know better.
Old Feb 12, 2008 | 11:04 PM
Scott Marzahl
Hi Mike,
I think the only thing he gets credit for is the broach marks on the pad.
I can't see anything else unless he has the dealer warranty paperwork.
To Is CE Stamping Valuable?
