Engine dies on the road....
Old Feb 11, 2008 | 06:58 PM
'Bochawa72's Avatar
'Bochawa72
Default Engine dies on the road....
383- 4spd- Holley blue mechanical fuel pump- 750Holley carb tuned by AED.
So a brief history.... Everything ran fine. Then it didn't. I pulled the rear needle and seat and there was a bit of trash in there and the bottom was cracked. So I replaced that and now she runs again. BUT..... When I get a little higher into the RPM's say 3000ish through first and second I'll about hit the speed limit and drop her into neutral and she just dies. SO I have to put it in 4th and dump the clutch cause I'm rolling down the road at 45mph with a dead car. Fires up fine and it's like nothing happened. Even if I leave her in gear and try to coast back down through the RPM's it'll stumble and act like it's trying to die. This wasn't happening before and all I did was change the needle and seat.... what could I have possibly have done? Or is this a new gremlin? I have no problems when I baby it and shift below 2500. But I have a freakin Corvette!!! I want to be able to get up and go every once in a while. So what do you guys think?
Old Feb 12, 2008 | 07:41 AM
'Bochawa72's Avatar
'Bochawa72
Old Feb 12, 2008 | 08:15 AM
gyopp's Avatar
gyopp
Sounds like more trash Collin. If you have a fuel filter you may want to repalce it and clean your carb again.
Old Feb 12, 2008 | 08:34 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You might also want to change the filter (sock) in the fuel tank.
To Engine dies on the road....
