flywheel
Old Feb 14, 2008 | 11:02 AM
RogieStone's Avatar
RogieStone
Default flywheel
It it time to start my new 383 stroker , but I dont know what starter to get. Is there any way to tell if I have a 153 or 168 tooth flywheel short of spining the fly wheel and counting? Also any suggestions on what to gap my plugs at.
Old Feb 14, 2008 | 11:30 AM
68/70Vette's Avatar
68/70Vette
I'd suggest the GM Performance Parts catalog ministarter GM PN 12361146. It has a dual mount bolt pattern so it will work with 153 tooth flywheels (12.75 inch) and 68 tooth flywheels (14 inch). It weighs only 10.5 pounds. I use one on my ZZ4.
Old Feb 14, 2008 | 11:59 AM
Ironcross's Avatar
Ironcross
The same starter you were using before the swap or transplant should be correct.
Old Feb 16, 2008 | 12:02 AM
maddmickey's Avatar
maddmickey
If you are running an HEI or an aftermarket ignition you can go .045 on your plug gap.
Old Feb 16, 2008 | 03:55 AM
Stroker-427's Avatar
Stroker-427
99% you have a 168 thoot flywheel....
To flywheel
