Front tire rub
Old Feb 15, 2008 | 09:37 AM
awest5321's Avatar
awest5321
Default Front tire rub
I just installed new 255/60/15 tires on my original style aluminum mag wheels and when I try to turn the wheel left or right the front of the tire will hit the front fender lip. Is there a fix for this problem besides flaring or trimming the fiberglass? The rims are stock 79 corvette issue mounted on my 75 vette, dont think there are any differences in the two yr model cars, donot want to get rid of my new tires either. Any ideas?
Old Feb 15, 2008 | 10:23 AM
7T1vette's Avatar
7T1vette
There is more clearance on the '79s wheelwell than on your '75. You basically have some limited choices:
1. Find where the rubbing is occuring and make clearance for it or install some kind of "stops" to prevent the rubbing from happening;
2. Buy or trade for some narrower wheels;
3. Go to 235 [or 245, if the rubbing is minor] tires at the front of the car.
I think that's about it. Good luck.
Old Feb 15, 2008 | 10:27 AM
croaker's Avatar
croaker
I have the same problem I swapped the aluminum for crager SS's same problem I had 245's I wound up going a lot smaller for piece of mind
Old Feb 15, 2008 | 10:58 AM
rponfick's Avatar
rponfick
I couldn't get 245 to fit on the front of my '69. So, had to go to 235. It seems like there is a wide variation in what will fit on any particular C-3.
Good luck.
Ralph
Old Feb 15, 2008 | 04:38 PM
nutsy's Avatar
nutsy
i went from 225s to 215s on my 72 for this problem. but difference in these 2 sizes was only around a quarter inch but it was enough. didnt want to chance ripping off fender.
Old Feb 15, 2008 | 04:51 PM
Hells Bells 73's Avatar
Hells Bells 73
i have 245/60/15 on my 73 .no rubbing , you have weak front springs.
Old Feb 15, 2008 | 07:14 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
255X60X15 on our 72, on full lock it just touches the frame. As Hells Bells73 said, you may have weak springs.
Old Feb 15, 2008 | 11:52 PM
7T9Shark's Avatar
7T9Shark
Weak springs you say?? Contrare'. If you examine the geometry closely, you will see that new springs may actually make the problem worse. The front lip of the C3 fender is contoured such that if you lower the chassis, the fender/tire gap will increase at the front where the interference is felt when the wheels are turned outward.
Old Feb 16, 2008 | 12:57 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Been there....done that on my 75 Vert! Went from 255 to 235's on the front cuz of the rubbin'
To Front tire rub
