Simple Balljoint question
Old Feb 17, 2008 | 01:17 PM
billsfan's Avatar
billsfan
Default Simple Balljoint question
I'm putting my upper control arms back together. The bushings went in easy, but I'm having trouble with the balljoints. When I drop the balljoint into the control arm, the lip on the top of the dust boot is sandwiched between the ball joint and the control arm. I cranked on the bolts a lot more than 25 ft/lbs, but there is still a slight gap between the ball joint flange and the control arm. What gives??
Old Feb 17, 2008 | 01:23 PM
Scott Marzahl's Avatar
Scott Marzahl
It sounds like you are installing the balljoints into the arm wrong. Without a pic its hard to say, but it sounds like you are installing them from the bottom and not the top of the arm??
Old Feb 17, 2008 | 01:53 PM
A88FXRS's Avatar
A88FXRS
Put The Ball Joint In From The Top, Bolt It In And Push The Rubber Boot On From Underneath Flush With The Bottom Of The Control Arm.
Old Feb 17, 2008 | 01:57 PM
billsfan's Avatar
billsfan
This seemed to me to be the logical way to do it. I wanted to be sure before I removed the boot. I guess that the spindle will hold the boot snug against the bottom of the control arm?
Old Feb 17, 2008 | 02:00 PM
billsfan's Avatar
billsfan
Nope. When I drop the balljoint in from the top, the rubber lip at the top of the dust boot sits on top of the control arm, with a 1/8" gap between the flange and the top of the control arm. Torquing down the bolts does not remove this gap. I thought that the ball joints were the easy part of this job!
Old Feb 17, 2008 | 02:16 PM
Scott Marzahl
You last statement does not make any sense, two of us just suggested to install the ball joint from the top of the A arm. The boot goes on after its installed.
Old Feb 17, 2008 | 02:56 PM
billsfan's Avatar
billsfan
That's what I learned. The boot goes on after the balljoint is installed. I was trying to install it with the boot on it.
Old Feb 17, 2008 | 07:59 PM
'75's Avatar
'75
only way to do it
To Simple Balljoint question
