What is the correct ride height
Old Feb 18, 2008 | 10:40 PM
Kent Hawkins's Avatar
Kent Hawkins
Default What is the correct ride height
What is considered the correct ride height for a 75 convertible with 255-60 tires on standard corvette rallys? I've got 271/4 in the front, but 30 in the back.
Old Feb 18, 2008 | 11:23 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
Maybe someone with a '75 AIM will chime in with the exact figures, but your Z and D heights at curb weight (fluids at capacity, including fuel)should likely be in the range of about 2.5 to 3", given a std suspension. Technically, these suspension geometry heights should be given a higher priority than other trim height measurements, such as fender heights.
Lower (to a point) is generally better for perf, and given the rear is easier to change, I'd suggest lower the rear to about 28" in your case. Long spring bolts for this are available thru many Corvette parts houses.
