odometer reset cable ?
Old Feb 21, 2008 | 10:36 AM
crf311's Avatar
crf311
Default odometer reset cable ?
anyone know how you remove the odometer reset cable. The speedometer is already out of the vette. I have it apart but a can't tell how I disconnect the little gear on the end which engages the milage wheels. Thanks
Old Feb 21, 2008 | 01:07 PM
Poppa Bud's Avatar
Poppa Bud
Cruise-In IX Veteran
St. Jude Donor '08 thru '13
On my 68 the cable screws out of the back of the housing. Is the cable stuck in the gear?
Old Feb 21, 2008 | 04:01 PM
Willcox Corvette's Avatar
0Willcox Corvette
Former Vendor
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15
The odometer reset cable screws I to the main speedometer can. This can has a nut made in to it that is threaded to accept the cable assembly. If you are removing the cable from the can, hold the aluminum nut with one wrench while turning the nut made on the cable with another one.
If you are trying to remove the odometer reset mechanism from the speedometer head. You can not remove this unless you remove face, the jewel plate with busing and the odometer first.
Once these items are out of the way, the odometer trip reset mechanism is held in place with a single slotted screw.
You can go to our site and downoload this picture of the parts I'm talking about. It will make it easier for you. http://willcoxcorvette.com/repairand...lp.php?hID=145 There are detailed instructions on how to remove the needle and the face on this page as well. While the speedometer pictured is not exactly like yours, most of the parts are so close you should be able to figure this out. If not email us at Willcoxcustomerservice@willcoxcorvette.c om
Willcox Inc.
Old Feb 21, 2008 | 04:40 PM
FeedVaal's Avatar
FeedVaal
That's what I call a supporting vendor!!!
To odometer reset cable ?
