remote entry/locks
Old Feb 22, 2008 | 06:53 PM
ngroat7007's Avatar
ngroat7007
Default remote entry/locks
How many people have it? can you have it? is it tough?
sorry if this is a stupid question but it would come up eventually
Old Feb 22, 2008 | 07:46 PM
Durango_Boy's Avatar
Durango_Boy
I installed electric locks and keyless entry in my '77. I bought the kit, which came with everything I needed. I mounted the actuators, rigged so they would work on my Vette, and I mounted the control modules behind the passenger dash knee pad.
The door side locks are the manual switches, so the key in the door will also unlock and lock both doors just as the remote and interior switches will.
I love my system.
Old Feb 22, 2008 | 07:49 PM
ngroat7007's Avatar
ngroat7007
I love my system.
I should have known db would have it
was rigging the actuators that big a deal?
Old Feb 22, 2008 | 08:43 PM
pbcanney's Avatar
pbcanney
I want this
Old Feb 22, 2008 | 09:17 PM
Durango_Boy
Nah, the hardest part was figuring out the difference in actuation. The actuators move about a full inch, but the Corvette linkages only moved half that. I had to use the washer to make it work so the actuators moved full travel and weren't stopped by the linkages bottoming out.
The actuators themselves are just screwed in place, and the wiring is all plug and play with the controllers.
Old Feb 22, 2008 | 09:25 PM
ngroat7007's Avatar
ngroat7007
do you still have the link to the kit you used?
Old Feb 22, 2008 | 09:27 PM
Durango_Boy
No, sorry. I got it off of Ebay like six or seven years ago. It was one of the few kits I found that DIDN'T have a remote start or alarm built into it. What I have is rare by today's standards.
Old Feb 22, 2008 | 10:13 PM
spedaleden's Avatar
spedaleden
Buy this and you'll be good to go;
2 of these
http://www.crutchfield.com/App/Produ...514DS24&tp=154
and a keyless entry or alrm w/keyless (make sure module put out a negative pulse for lock/unlock)
about $80 - $100 for quality parts
Old Feb 22, 2008 | 10:34 PM
dalewilson99's Avatar
dalewilson99
I put keyless on the 81 when I replaced the failed alarm module. It was easy but I needed 2 buffer relays to convert from a negative trigger to reverse polarity that the existing power door locks use.
Dale
Old Feb 23, 2008 | 12:28 AM
chvet73's Avatar
chvet73
Get this, my kit came from JC whitney about 10 years ago. I bought it becaues the cost was about $30 at the time. I just followed the instructions. Mine looked about the same as the pictures above. Except the actuator rod clamped with a uclamp and screw to the horizantal rod. I set it up to work with my alarm switch. It has been trouble free since. I love the set up.
To remote entry/locks
