What motor is this????
Old Feb 22, 2008 | 06:54 PM
Dante7's Avatar
Dante7
Default What motor is this????
Numbers off pad in front of passenger side head.
V0808TJW CA1106430 off the head J84 462624
Please help me out I know its not the orginal I got lied to when i bought and now I am trying to make heads or tails out of what i have???
Sorry I made a mistake it was TJW not x I am sorry
Old Feb 22, 2008 | 07:07 PM
Scott Marzahl's Avatar
Scott Marzahl
That head number was used from '75-86, 76cc smog head, so by the date code J84, I would say that they were cast in Sept-08-1984.
http://www.mortec.com/castnum.htm
The block suffix code TJX was used in '72 for a 307, '73 and '78 in 350s for trucks. What is the block casting number and date code?
The CA number is probably the VIN number.
http://www.nastyz28.com/gm-chevy-cod...s-suffix-8.php
Old Feb 22, 2008 | 07:36 PM
Dante7's Avatar
Dante7
I made a mistake in the orginal posting with the motor numbers I have fixed it now sorry for any problems scott
Old Feb 22, 2008 | 09:07 PM
Scott Marzahl
Well it looks like it could be a '72 307 or a '73, '74 or 1980 4 bolt 350 from a van or truck.
Find the casting number and date code on the block to pin this down.
Old Feb 22, 2008 | 09:28 PM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
Here's a link to all the numbers and dates etc.
Old Feb 23, 2008 | 02:01 PM
Dante7's Avatar
Dante7
I found the casting numbers on the block the only problem is they are unreadable it looks like someone intentionally damaged the at some point in time.
The date code is G289
Can anyone tell me what the block is that I have does it have 4 bolt mains and what type of pistons did it orginally have... I just want to know if this motor is possibly worth trying to build for more power
To What motor is this????
