74 drag vette
Old Feb 22, 2008 | 11:44 PM
thunderlips's Avatar
thunderlips
Default 74 drag vette
I am considering buying this corvette i saw advertised with pics, and have a few newb questions- here is part of the ad :
"The motor is 100% custom. It was machined by a company that does Pro Drag Motors. There were only 2 of these motors ever built. The engine is a high compression motor 1000 horsepower and shifts at 10,000 RPMs. It has 13 to 1 compression. The engine itself cost 25K dollars. It is hooked up to a turbo 400 tranny that leads to 4:11 gears. There is a Hurst slapstick shifter and an electric fan. The motor is setup for NOS and runs on 120 octane. You can switch the carburetor to run it on a lower octane."
If it shifts at 10000 rpm, can i drive it around town in its first gear?
Or does this mean it has the abilit to shift at 10,000 and can shift lower than that?
how many gears does a turbo 400 have?
would this be hard to shift for an average person? dangerous to drive on the street?
Is there i way i could make it shift like a somewhat normal car or is it the way the motor was made?
THANKS in advance!!
Old Feb 23, 2008 | 12:02 AM
maddmickey's Avatar
maddmickey
This would not be a good car for the street!! I really dont think the motor would run on pump gas, too high compression. The trans probably has a way high stall, and would overheat and burn itsself up cruising around town. If you are looking for a street car I would find another one.
Old Feb 23, 2008 | 12:30 AM
BigBlockk's Avatar
BigBlockk
This has got to be some kind of joke.
If you don't know how many gears a Turbo 400 has old Corvette's are not the car for you.
BigBlockk
Later.....
Old Feb 23, 2008 | 12:41 AM
milo30's Avatar
milo30
This is for racing only not for the street. to answer your other questions
A turbo 400 has 3 gears. It redlines at 10,000 RPM. It would shift gears using all 3 gears in town. This is the type of car that gets trailered to the track, raced then trailered home.
Old Feb 23, 2008 | 01:13 AM
l88rocket's Avatar
l88rocket
No kidding a T400 is a 3 speed auto, The motor is a full race motor changing the carb has nothing to do with what gas you run in it. It will need race fuel regardless and you would burn the motor up changing carbs. Sounds like a BBC I wouldnt shift it anywhere near 10k, unless you want the bottom end vented.
I wouldn't run it on the street if you aren't used to race cars. this will be a complete monster.
Old Feb 23, 2008 | 05:07 AM
mr nasty's Avatar
mr nasty
[QUOTE=l88rocket; I wouldnt shift it anywhere near 10k, unless you want the bottom end vented.
[/QUOTE]
hehehehehehehehehe
Old Feb 23, 2008 | 05:51 AM
Greg's Avatar
Greg
Just another Corvette guy
BigBlockk
Later.....
Old Feb 23, 2008 | 10:27 AM
thunderlips
I told you i was a newb, knew the 350 was a 3 speeed auto so i thought the 400 would have 4; no need to be a c*ck. its also a manual not an auto in this one. heres the link, i just thought it was a reallly good deal to pass up.
http://cgi.ebay.com/ebaymotors/ws/eB...ksid=p3907.m29
Old Feb 23, 2008 | 11:04 AM
Glass Act's Avatar
Glass Act
From: 406ci SB, AFR 180 Heads - 490 HP @5,600 RPM 529 lb-ft @ 4,100 RPM
I'd pass on it, after reading the description I think their full of it. The pictures don't reflect a 10k paint job, tires are flat, I'd have to say the car was not well look after through the years. The price is up to $5k now not worth that.
Your profile say's you have a 1978 - 454, spend your time, money and effort on that car, at 18 you have a way to go before you enough wrench time for a drag car.
Not trying to be real negative here, just calling it as I see it, you ask what we thought, thats my 2 cents.
Old Feb 23, 2008 | 02:45 PM
l88rocket's Avatar
l88rocket
That car is a piece of crap. you would spend a fortune to make it right.
Old Feb 23, 2008 | 03:02 PM
PRNDL's Avatar
PRNDL
w - t - f ??
is that a vegetable garden in front of the windshield? seriously, what is all that crap?
Old Feb 23, 2008 | 04:00 PM
tellcom2001's Avatar
tellcom2001
car looks like junk..my motor looks better and didnt cost 25k i smell an ebay snow job
Old Feb 24, 2008 | 10:19 PM
427Hotrod's Avatar
427Hotrod
2020 C2 of the Year - Modified Winner
2020 Corvette of the Year (performance mods)
C2 of Year Winner (performance mods) 2019
2017 C2 of Year Finalist
Hey you never know. I see aluminum heads, good intake and a Dominator. Maybe it's a 540 or larger? Maybe it has a Tom's IRS under it? It may have lots of good parts there. I'd ask questions......
JIM
Old Mar 2, 2008 | 08:53 AM
redwingvette's Avatar
redwingvette
Originally Posted by thunderlips
I told you i was a newb, knew the 350 was a 3 speeed auto so i thought the 400 would have 4; its also a manual not an auto in this one. heres the link, i just thought it was a reallly good deal to pass up.
The trans is a auto setup with a manual shift body. It is still an auto trans but you have to tell it when to shift. Not a car for the street.
Old Mar 2, 2008 | 11:40 AM
yellow 72's Avatar
yellow 72
St. Jude Donor '09
JIM
Old Mar 2, 2008 | 12:41 PM
dahctor's Avatar
dahctor
This car would not be streetable and not worth the money he probably wants out of it.
Old Mar 2, 2008 | 01:27 PM
bojangies46's Avatar
bojangies46
Originally Posted by yellow 72
Old Mar 5, 2008 | 05:28 PM
BigBlockk's Avatar
BigBlockk
There appears to have been some creative editing done in this thread.
BigBlockk
Later.....
To 74 drag vette
