aluminum head temp.
Old Feb 26, 2008 | 01:44 PM
fugawi's Avatar
fugawi
Default aluminum head temp.
well i bit the bullet, and got a mark viii fan ,and dcc control.brian at delta control said it should stabilize about 185 degrees. is this temp ok for aluminum heads. got a 180 themostat. should i go with a 170 or 160..
Old Feb 26, 2008 | 05:54 PM
fugawi's Avatar
fugawi
bump for the evening rush...
Old Feb 26, 2008 | 06:02 PM
Scott Marzahl's Avatar
Scott Marzahl
More than adequate for aluminum heads, they see the same temps as cast iron heads during normal operation. I'd go with a 180.
Old Feb 26, 2008 | 06:03 PM
mrvette's Avatar
mrvette
180f is fine for the stat rating....buy one that fails in the OPEN position, many don't....
Murray is supposed to be that way....
To aluminum head temp.
