Leaking gas at the filter..??
Old Feb 27, 2008 | 12:33 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
Default Leaking gas at the filter..??
Ok I have a leak at the gas filter on my QJ .....Not at the gas line connect but at the big nut that holds the filter in...Is there a gasket that goes on that nut or a plastic ring or something??????
Thanks everyone....
Old Feb 27, 2008 | 12:39 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Yes, there should be a gasket there.
Old Feb 27, 2008 | 12:47 PM
1Fordman's Avatar
1Fordman
They used a thin plastic/nylon material sealing ring.
Old Feb 27, 2008 | 12:55 PM
ptroxx's Avatar
ptroxx
Thanks everyone....
Should any parts store have it or??
Old Feb 27, 2008 | 01:49 PM
Jud Chapin's Avatar
Jud Chapin
They may be a tough item to find. If you have a carb shop in your area, you might call them. You might also try your dealer.
Old Feb 27, 2008 | 01:53 PM
Jud Chapin's Avatar
Jud Chapin
Zip carries them if worst comes to worst, but call around locally first.
http://www.zip-products.com/Zip/prod...54F23B905BF37C
Old Feb 27, 2008 | 04:24 PM
ptroxx's Avatar
ptroxx
Thaks for the help guys ... shes fixed...
Old Feb 27, 2008 | 04:53 PM
Jud Chapin's Avatar
Jud Chapin
Good deal!
Old Feb 27, 2008 | 05:15 PM
ptroxx's Avatar
ptroxx
Thanks....... Now im working on my Battery draw...
To Leaking gas at the filter..??
