1980 Smog Pump bracket ??
Old Feb 27, 2008 | 01:47 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Default 1980 Smog Pump bracket ??
I have the larger smog pump bracket that bolts in at the water pump and intake manifold mounted. I'm not sure where to mount the other. My AIM shows three mounting locations. Which is correct?
Old Feb 27, 2008 | 02:14 PM
stingr69's Avatar
stingr69
They are the same.
Do you have K-73?
-Mark.
Old Feb 27, 2008 | 02:19 PM
Ak. Mal's Avatar
Ak. Mal
Is K73 the stud for the head? If so, then no. I'm trying to put a system back on the car that I've never seen in place.
Does it mount to the same place as the alternator bracket?
Old Feb 27, 2008 | 02:34 PM
1980 blue L48's Avatar
1980 blue L48
I just went out and looked a mine. Your steel air pump bracket mounts to the top water pump stud at drivers side. The alt bracket mounts to the stud that also is the aluminum alt lower brace. (this is in the cyl. head) Hope this helps
Old Feb 27, 2008 | 02:36 PM
stingr69's Avatar
stingr69
K-73 is an option. I don't have anything to decode it but the previous poster is right.
-Mark.
Old Feb 27, 2008 | 02:42 PM
Ak. Mal's Avatar
Ak. Mal
Does the bracket rest on the water pump or is there something between the two?
Old Feb 27, 2008 | 02:49 PM
1980 blue L48
Use center pic on your assembly manual.air bracket mounts by itself on W/P stud. Alt lower aluminum brace inner most stud (in cyl. head) is also sharred by the alt. belt tension bracket.
Old Feb 27, 2008 | 03:29 PM
Ak. Mal's Avatar
Ak. Mal
Ok, I think I get it now. Thank you for clearing this up.
To 1980 Smog Pump bracket ??
