New tach drive gear
Old Feb 28, 2008 | 12:35 PM
kansas123's Avatar
kansas123
Default New tach drive gear
Before I install a new tach drive gear, what kind of grease should I use on it? White grease okay? There were not instructions with the washer, button, gear and coupler. Thanks.
Old Feb 28, 2008 | 12:39 PM
GTR1999's Avatar
GTR1999
I would check the mesh before you install the dist back in the car. If it binds by hand the eng will tear it up in no time. Otherwise any good grease will work.
Old Feb 28, 2008 | 12:46 PM
S489's Avatar
S489
i always end up having to replace both gears . . . good luck!!!
Old Feb 28, 2008 | 05:16 PM
7T1vette's Avatar
7T1vette
Use a "moly" gear grease. White lithium is OK for slow, rubbing metal parts...but the dizzy gears run at 1/2 engine speed.
Old Feb 28, 2008 | 09:45 PM
wombvette's Avatar
wombvette
Do not under any circumstances replace just the cross gear. You will be buying another gear and a shaft. Replace both together.
To New tach drive gear
