76 electric choke conversion
Old Feb 28, 2008 | 05:16 PM
pete44's Avatar
pete44
Default 76 electric choke conversion
Just purchased electric choke kit... had a question about positioning of it..should the electrical connector be on top when inserted into side of carb..that would make the position of the spring "end" on the bottom..the spring seems to give counter-clockwise thus closing "choke-flap" on carb to go to close position....when 12Volt applied does the spring swing counter-clockwise causing flap to close upon cold cranking..and what makes it go back to start position...flap open?.(heat???)....thanks,Pete
