identifying 68-71 speedos
Old Mar 1, 2008 | 02:36 PM
yurgutis's Avatar
yurgutis
Default identifying 68-71 speedos
how do you tell the difference between 68-69 with or without speed warning indicator? and through 71 without indicator? thanks
Old Mar 1, 2008 | 04:25 PM
Alan 71's Avatar
Alan 71
The only difference I know of is that from 68 till the first month of 70 production, the high beam indicator lens was RED, after that it was BLUE. All those years had the greenish numerals.
Regards,
Alan
Old Mar 1, 2008 | 04:36 PM
dmayhew's Avatar
dmayhew
In addition to Alans remarks , It is my understanding that the speedo / tach cable on a 68 threaded in. The later cars use a clip to hold the cable after it is slide into the receiver.
I believe the basic 1969 thru 1971 speedo assy will interchange
and you coulld swap out the plastic piece that Alan refered to that gives the red or blue color to the high beam indicator.
As for the W/O speed warning. I do not think that was offered after 1969? Will need to allow others to confirm or correct that detail.
David
To identifying 68-71 speedos
