Battery question
Old Mar 2, 2008 | 08:14 PM
BassCat's Avatar
BassCat
Default Battery question
I plan on attending a few car shows this spring and summer and a couple of them will be at casinos. Although the casinos have their own security, I'd still like to disable the battery in my 77 Vette while it's parked on their lot overnight. Is it safe to disconnect just one of the battery cables, does it matter which one, or should I disconnect both? I don't mind disconnecting both, just thought it would save time if I only had to do one.
Thanks,
Kenny
Old Mar 2, 2008 | 08:32 PM
dannyman's Avatar
dannyman
I always disconnect the negative first and install negative last. Have you considered a battery disconnect? You should if you want to disconnect multiple times.
Old Mar 2, 2008 | 08:39 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
delete
Old Mar 2, 2008 | 08:45 PM
BassCat's Avatar
BassCat
Where exactly would the starter harness be on a 77 Vette???
Old Mar 2, 2008 | 08:49 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
follow the wires up from the starter on the passenger side. They will run into a connector on the firewall just to the right of the wiper motor.
Old Mar 2, 2008 | 08:55 PM
Speed Hound's Avatar
0Speed Hound
Former Vendor
You could take a 5/8" socket with you and disconnect the ground from the frame. You'd just have to lay on your back and reach under the car. Or a quick disconnect mounted on the side of the battery works great. If you want theft prevention, unplugged the batt wire off the distributor as well. The car will never crank that way.
Old Mar 2, 2008 | 09:23 PM
BassCat's Avatar
BassCat
Thanks for all the advice. While we're on the subject of theives, my original factory alarm worked up until last week. Just stopped working overnight. Does anyone know where the alarm is actually located on a '77 vette so I can do some troubleshooting?? Thanks.
Old Mar 3, 2008 | 03:29 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
my 78 is located on the driver's side fender under the mc. I've seen the horn in there anyway for the alarm, I havent gotten that far along on mine yet to trace it all down.
Old Mar 3, 2008 | 04:20 PM
gofastvette's Avatar
gofastvette
Pull the coil wire
Old Mar 3, 2008 | 04:25 PM
rudolph schenker's Avatar
rudolph schenker
I bought one of these.
http://www.jegs.com/i/Painless/764/30204/10002/-1
Old Mar 3, 2008 | 07:18 PM
SIXFOOTER's Avatar
SIXFOOTER
Thats pretty slick, almost what I am looking for. I am looking for a relay like that with 2 operating coils, 1 puls on and 1 pulse off, like on big airplanes.
That one says contious duty, I wonder if it realy is
To Battery question
