Pilot Bushing Question
Old Mar 2, 2008 | 10:20 PM
724544SPD's Avatar
724544SPD
Default Pilot Bushing Question
When my BB came back from the machine shop the pilot bushing was not pressed all the way into the crank. I'm installing a new bushing that came with my clutch set-up. How far in the crank should the bushing be installed? The GM overhaul manual shows an illustration that indicates that the bushing should be flush in the crank. Any advice on this?
Old Mar 3, 2008 | 12:00 AM
1981Z06Vette's Avatar
1981Z06Vette
It should be flush with the back edge of the crank.
Old Mar 3, 2008 | 12:09 AM
sperkins's Avatar
sperkins
Old Mar 3, 2008 | 09:33 PM
724544SPD's Avatar
724544SPD
Do you mean the surface on the crank that the flywheel bolts to or the recessed area that is deeper than that? It seems like it would need to be flush with the recessed area. That is also what the illustration shows in the GM overhaul manual.
Old Mar 3, 2008 | 10:52 PM
sperkins's Avatar
sperkins
There is a small taper on the end of the crankshaft to allow easy installation of the bushing. Install the bushing flush to where the taper ends.
Old Mar 4, 2008 | 02:30 AM
Solid LT1's Avatar
Solid LT1
Flush with the recessed area of the crank. Make sure your bearing is "non-magnetic" if you can pick it up with a magnet, it may squeel after installation. Pioneer makes a true Bronze bushing most of th eclutch kits have CHEAP Chinese junk packaged with them. Non-magnetic=GOOD! Magnetic=BAD!
Old Mar 4, 2008 | 08:43 PM
724544SPD's Avatar
724544SPD
Mine bushing cam from Ram. Not sure if it was magnetic or not. It broke while I was tapping it into the crank. Any idea where I can get the Pioneer bushing that you mentioned?
Also...anyone have installation tips? I don't want to have to do this a third time.
Old Mar 4, 2008 | 08:58 PM
1981Z06Vette
Lots of parts store carry them, but you can call them at 601-483-5211 for a local distributor. I always tap them into place using a similar sized deep well socket.
Old Mar 4, 2008 | 09:06 PM
724544SPD's Avatar
724544SPD
Thanks for the info. I'll give them a call. I used the socket method, I'm thinking that next time I'll put a bit of grease on the outside of the bushing.
Old Mar 4, 2008 | 09:10 PM
Whiplash71's Avatar
Whiplash71
It's a press fit so I'm not sure you want to use any grease. Not sure if it matters though.
I put mine in the freezer overnight before I install.
Old Mar 5, 2008 | 12:42 AM
Solid LT1's Avatar
Solid LT1
Most automotive machine shops carry the Poineer line. You may want to measure the outside if the bushing and the hle in the crank before driving the next bushing in. There should be no more than about 0.003-0.005" of interference fit between the 2 pieces.
To Pilot Bushing Question
