would these wheels fit?
Old Mar 3, 2008 | 11:49 AM
chevyfas's Avatar
chevyfas
Cruising
Default would these wheels fit?
they are torque thrust II, Rear 18 x 10 w 255/45 x 18 tires
-Front 17 x 8 w 245/45 x 17 tires
it would go on a 74 stingray with stock suspension.
Any help is greatly appreciated!
Old Mar 3, 2008 | 12:32 PM
vho69's Avatar
vho69
the 17 will fit the fronts but the 18 x 10 won,t fit the back without at least moving the parking brake bracket and maybe some spacers to,than they might start to rub the fenders. you would most likely need to use some off set trailing arms.
Old Mar 3, 2008 | 03:10 PM
dewcustom's Avatar
dewcustom
I have 18x10's on the rear and had 255/45's but did not lookgood so i put those tires onthe front 18x8's and put 295's on the back
Old Mar 3, 2008 | 08:53 PM
chevyfas's Avatar
chevyfas
Cruising
so should i go with 17x 8 all the way around, or can i do a 17x10 in the back? Also, what tires would be best for those wheels? Sorry guys, i know nothing about wheels, and really appreciate the help.
To would these wheels fit?
