Ported Vacuum switches
Old Mar 3, 2008 | 03:09 PM
Ak. Mal's Avatar
Ak. Mal
From: Kansas City, MO ...I'd like to go fishing and catch a fishstick. That'd be convenient. - Mitch Hedberg
Default Ported Vacuum switches
I bought my car (1980) without any of them installed, now I need them to finish putting the stock intake,carb,emissions stuff back on. KENS80V was nice enough to email me a diagram for the engine vacuum hose routing. I see 4 TVS listed on it, which I'm guessing means Temp. Vac. Switch? When I look up ported vac sw. on Advanced Auto parts website, they list several that are for my car, but I noticed that between the different manufacturers, they all only have 4 different colored switches, blue, white, purple and black. If I need all four colors, can anyone tell me which one goes where and where they are installed?
The diagram lists:
Distr TVS
EFE TVS
EGR TVS
TVS (shown in the air cleaner)
Old Mar 3, 2008 | 04:10 PM
SIXFOOTER's Avatar
SIXFOOTER
send me the diagram, I'll figure it out for you
Old Mar 3, 2008 | 04:14 PM
Ak. Mal's Avatar
Ak. Mal
Old Mar 3, 2008 | 04:18 PM
SIXFOOTER's Avatar
SIXFOOTER
This one will do for the first 2
http://www.ecklers.com/product.asp?p...0&dept_id=1177
This one for the EGR
http://www.ecklers.com/product.asp?p...9&dept_id=1268
Those control vacuume to the distributor, EGR and EFE valves based on engine temp
the one in the air cleaner is different, it controls vac to the little flapper in the air cleaner horn to direct hot air from the stove pipe on the exhaust manifold into the air cleaner to warm up the carb quickly.
I am looking for that one
Old Mar 3, 2008 | 04:26 PM
SIXFOOTER's Avatar
SIXFOOTER
Hmmm...the one oin the bottom of the air cleaner is drawn weird. I can't tell if the Yellow vac line goes thru it, but I wouldn't think so, doesn't make sense for it to.
Do you have the temp sensor in the bottom of the air cleaner? It should say AC on top and have 2 nipples on the bottom.
Ak. Mal's Avatar
Ak. Mal
Thanks. Can you tell me where they are installed? Is it EFE and Distr are in the thermostat housing and the EGR in the manifold?
What can I do to cover the hole in the air cleaner assembly since it looks like that switch is unavailable?
Old Mar 3, 2008 | 04:31 PM
Ak. Mal's Avatar
Ak. Mal
Based on your description, I would say that the temp sensor in the bottom of the air cleaner is present.
One other quick question, what size is all of this vacuum tubing? I need to know what to purchase.
Old Mar 3, 2008 | 04:32 PM
KENS80V's Avatar
KENS80V
Distributor TVS-ported vac and N/C (normally closed)
EGR TVS-ported vac and N/C (normally closed)
EFE TVS-manifold vac (non ported) and N/O (normally open)
EFE AC delco #212-72
Standard #PVS48
EGR AC Delco #212-352
Standard #PVS27
Dist AC Delco #212-12
Standard #PVS16
Old Mar 3, 2008 | 07:31 PM
Ak. Mal's Avatar
Ak. Mal
Thanks guys.
Even with part numbers I can't tell which color switch is for which system.
Do I have this right?
EGR TVS goes in the intake next to the thermostat housing
EFE and Dist TVS go in the Thermostat housing
Old Mar 3, 2008 | 09:09 PM
SIXFOOTER's Avatar
SIXFOOTER
That sounds right. If your going thru all the BS to do this, go ahead and check Dr Rebuild, he has color correct vac line sets and diagrams for all that stuff, might even have the TVS for the air cleaner
Old Mar 3, 2008 | 09:21 PM
SIXFOOTER's Avatar
SIXFOOTER
Here you go
http://www.docrebuild.com/dr-r-web/AIR-CL2.pdf
http://www.docrebuild.com/dr-r-web/EMISS-HOSE.HTML
Old Mar 3, 2008 | 09:47 PM
FB007's Avatar
FB007
The diagram lists:
Distr TVS
EFE TVS
EGR TVS
The four colors, blue, white, purple, and black are the temperature at witch they open and close. NAPA is the best source for these. Use caution. Canadian cars use different temp TVSS than Cal, or 49 state cars.
Old Sep 1, 2008 | 09:28 AM
c3corvettes's Avatar
c3corvettes
Did you ever find this one? What color was it and how many ports were on it?
Old Sep 1, 2008 | 11:43 AM
Project80's Avatar
Project80
Standard #PVS48
Standard #PVS27
Standard #PVS16
Great info, thanks!
Old Sep 1, 2008 | 12:13 PM
stingr69's Avatar
stingr69
Two shown in the air cleaner
two shown in the thermostat housing.
Hope this helps,
-Mark.
Old Sep 18, 2020 | 07:19 AM
Dee69911's Avatar
Dee69911
Originally Posted by ak. Mal
based on your description, i would say that the temp sensor in the bottom of the air cleaner is present.
5/16"
Old Sep 18, 2020 | 07:31 AM
Dee69911's Avatar
Dee69911
Hope this helps,
-Mark.
can I get these photos please, I'm doing the same thing on my 1980 corvette L-82 automatic ,, I too need these switches, I have the purple in my intake & a red one sticking outta the side of my dual air cleaner & the AC one inside air cleaner,, I guess I'm in need of the others, please advise..
Old Sep 18, 2020 | 02:41 PM
stingr69's Avatar
stingr69
hope the OP got his hoses hooked up. It was 12 years ago.
You probably already have this one.
Here is the color coded diagram in case it helps someone
To Ported Vacuum switches
