Pushrod Length
Old Mar 5, 2008 | 01:09 PM
Bowerss2's Avatar
Bowerss2
Default Pushrod Length
I am getting Brodix IK180 heads, and 1.5 roller rockers, what length of push rods should i use? I have been told to just use the stock length, what is that? thanks,
Steve
Old Mar 5, 2008 | 01:45 PM
Scott Marzahl's Avatar
Scott Marzahl
Start with the stock length and use a cheap plastic pushrod length checker to verify that it is correct, or check the rocker to valve stem tip contact pattern with a little grease.
Old Mar 5, 2008 | 05:01 PM
GlockGuy's Avatar
GlockGuy
You are going to have to measure to get the best length push rod.
Old Mar 5, 2008 | 05:08 PM
Bowerss2's Avatar
Bowerss2
haha thanks, i messed up my leg, so i have a lot of time to sit around and tinker on things.
Old Mar 10, 2008 | 10:55 AM
steve007's Avatar
steve007
Cruising
i have 1.6 roller rockers,the roller is not on the ceter of valve,its down towards the exhaust,do i use longer or shorter push rods to correct,thanks
To Pushrod Length
