ballast mounting position?
Old Mar 6, 2008 | 07:29 AM
ace_cobra's Avatar
ace_cobra
Default ballast mounting position?
where are you supposed to mount an ignition ballast on a 70 vette?
Old Mar 6, 2008 | 12:18 PM
Mike Ward's Avatar
Mike Ward
You're not. There's no seperate ballast resistors on C3s newer than 69 (IIRC) The required resistance is built into the end of the factory installed wire. If somebody has removed that wire, then mount the resistor where ever you like near the coil.
