"why recreate the wheel"
Old Mar 6, 2008 | 10:13 PM
race2fast's Avatar
race2fast
Default "why recreate the wheel"
I know others have done the same as I am trying to do.
I am in the process of making a 69 corvette into a healthy street car. I wonder what are the optimal tire/wheel combinations I can use.
My current set up is total stock suspension configuration (std trailing arms) and full L88 type body flairs (front and rear ).
Any cool pictures?
Thanks a bunch.
Jim
Old Mar 9, 2008 | 10:16 AM
3JsVette's Avatar
3JsVette
What diameter wheels are you going to use?
If you're thinking of 15s - check out Panic's or Stan's combination (Roadracevett - spelling?) Try searching "minilites" I think.
For 17s:Fronts 17x9.5 with 4 to 4.5 backspace and a 275/40 tire. Rears 17x11 with 4 to 4.5 backspace and a 315/35 tire. I went with 4.5 backspace front and rear but the car is going to be built around the wheels and tires - meaning the flares aren't on yet and the suspension is VB mono front and rear.
For 18s:Front 18x9.5 with 4.5 backspace and a 275/35 tire. Rears 18x12 with 5" backspace and a 335/30 tire.
A note of caution this info will get you close. It seems all these cars are a little different. Some guys claim to get a little rubbing on the inside in the front and in the rear parking brake cable brackets and sway bars sometimes interfear. The suspension you use will also make a difference. As far as hitting the fenders looking at your picture I think you'll be safe with what I gave you. You may have to be carefull on the inside with parking brake or rear sway bar. Good luck with whatever you decide.
Old Mar 9, 2008 | 09:21 PM
1981Z06Vette's Avatar
1981Z06Vette
Not to hijack (since the OP's question was already answered), but what works best for a non-flared C3 with offest trailing arms? I'm leaning towards 17s or 18s.
Old Mar 10, 2008 | 12:56 PM
ktmdon's Avatar
ktmdon
Default Avon tires ?
Has anyone considered Avon CR6ZZ 245/60VR15, my understanding is they are made for Roger Kraus Racing for A.C. Cobras. Looks like a great performance tire, a bit on the expensive side. They are at "rogerkrausracing.com".
Old Mar 10, 2008 | 01:16 PM
Gordonm's Avatar
Gordonm
Sent you a PM on this.
Old Mar 10, 2008 | 01:42 PM
2000FRCZ19's Avatar
2000FRCZ19
St. Jude Donor '12
could you send me one too?
Old Mar 10, 2008 | 01:55 PM
Gordonm's Avatar
Gordonm
Sent.
To "why recreate the wheel"
