Offset trailing arms
Old Mar 7, 2008 | 09:54 AM
speedsk899's Avatar
speedsk899
Default Offset trailing arms
I am interested in exactly which way the offset is. If I understand it right, with the offset trailing arms you can fit 2" wider tires on it. Am I correct? any help would be great!
Old Mar 7, 2008 | 10:57 AM
vho69's Avatar
vho69
the hub wwhere you bolt the wheel on is still a stock measurement, the trailing arm its self is off set inward so you can put a wider wheel on to the inside
Old Mar 7, 2008 | 12:38 PM
Dustup7T2's Avatar
Dustup7T2
Terrorizing Orange Cones
speedsk899:
how's this to give a clue? I'm planning a 18x9.5 wheel with 5" backspace. No bodywork either. The wheels are still enroute so can not confirm but I have faith that certain members of the CF do not speak with forked toungue.
Can't hurt, right?
To Offset trailing arms
