Air Conditioner
Old Mar 10, 2008 | 12:57 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Originally Posted by rayluka
Gonna pull everything apart tonight and clean it for starters. Im sure the thing is full of crap so I will check all the other things Ive been advised of...thanks, and it is R12. And DB thanks for the email
I wouldn't do anything until I verified the pressures weren't within specs. You can check the pressures in a couple of minutes. If you don't have the gauges, take it to someone. You can spend many hours pulling things apart, particularly the evap box, and accomplish nothing if it's fairly clean.
Old Mar 10, 2008 | 01:00 PM
markdtn's Avatar
markdtn
Originally Posted by Five-spot
Just a thought, the old Harrison compressors weren't the best in the business when they were new. What about switching to a newer style compressor?
Just power hungry, not bad. If they were bad they would not have been used by John Deere, Mercedes, etc. into the late 80s. The A6 WAS the best in the business at that time. How many Chrysler compressors from that era are still in use today, or for that matter-while better-even the big Tecumseh compressors on Fords?
Old Mar 13, 2008 | 09:47 PM
s79vette's Avatar
s79vette
I know this is a few days late but does your car like mine have a valve on water line to heater core, ie; temp. control?Mine was leaking real bad so I unscrewed hose punchlock on intake and installed a 1/4 turn ball valve with male threads on one side and female on other. Then put screwed punchlock into valve and attached hose. Now car is cooler driving without having to run air with valve shut. On cool mornings it only takes a second to open hood to open valve to allow hot water to heater.The little bit of hot water in heater core will warm up cold air from air conditioner.Just a small bit from my experience. Steve
