what do you think my hp will be with this setup?
383 stroker,vic jr 215 runner heads,300 dur,550 lift roller cam ,full roller,144 blower,demon 750 or 800 cfm carb,super comp headers,4 speed manual aluminum flywheel,I am hoping to try and get around 600 hp.can i get there with this setup?
It seems to me as though the 144 blower is going to be out of steam long before you maximize the flow of the heads. I wonder about using an AFR
head and a magnacharger or nitrous setup. I have not seen any data that supported an advantage to using AFR as opposed to an Edelbrock head.
This seems like a high rpm engine and I dont know of any test data that shows the 144 to be efficient at high rpms. It seems to me the intake charge begins to gain a significant amount of heat. good luck
