top end combo recommendations?
Old Mar 9, 2008 | 02:33 PM
MS69 350/4-speed's Avatar
MS69 350/4-speed
Default top end combo recommendations?
I'm toying with the idea of having the top end of my engine updated for performance and wanted your opinions on some good setups for what I have?
The engine has been gone throught recently with some mild HP additions, intake, better cam and carb.
I have a 69 350 / 350 HP car with a 4-speed and 4.11 gears.
It currently has the original iron heads and a LT1 solid lift cam and a Torker II intake and a new 650 DP carb.
I;m getting new exhaust put on the car with ceramic headers and wanted to know of some good, Head, intake, cam, Carb combos that will reall make this vette scream... I want to keep it very streetable. But would like to get in the 415 - 430 HP range.
I'm really looking for low end toss you in seat....Hell yea... and up to 6,000 RPM power, Its a street car so I plan to keep her at 6,000 RPM or below. Not a race car or drag car, just a weekend toy!
It has 11.1 compression stock. Just looking for some great combos you have found to work great and are very streetable.
I also plan to keep the stock hood, so it must be low... no highrise intakes.
Thanks,
Old Mar 9, 2008 | 03:04 PM
Little Mouse's Avatar
Little Mouse
Keep the manifold, 650 DP, use a set of 180 AFR or IK180 Brodix heads.
Your compression combined with a mild enough cam to only pull to
6000 may give you some headaches on pump fuel.
Old Mar 9, 2008 | 07:04 PM
couperdecar's Avatar
couperdecar
If you want low end power you're talking torque. Pull the 4 spd and put in a 5 spd with a deeper 1st gear.
Old Mar 9, 2008 | 08:53 PM
milo30's Avatar
milo30
You should be able to use a hi rise intake if you use the right air cleaner with it. It would be tight but it fits under the stock hood.
To top end combo recommendations?
