Headman header?
Old Mar 9, 2008 | 06:31 PM
V-Rod's Avatar
V-Rod
Default Headman header?
What's wrong with Headman's product for side pipes? are they that bad? One says yes, other says no problems. I know Stahl is an option but at over twice the cost? and one person said he had a serious issue dealing with them over a fitting problem. thanks for any imput.
Old Mar 9, 2008 | 06:41 PM
jbowles49's Avatar
jbowles49
I installed them on my 80. Absolutely easiest install I've ever done. If you're looking for a product to go racing Stahl has a great reputation. For every day street use buy the Hedman.
Good luck
Old Mar 9, 2008 | 07:50 PM
gdh's Avatar
gdh
Hedman are very good budget headers, I have a set on my 383 stroker, they were inexpensive and good quality although they missed a spot on the weld, but that was a 10 sec. fix at a bud's place. It all depends on what you want them for, Hooker are a notch up in quality, and Stahl above that. I will be changing from the Hedmans to either Hooker or Stahl this spring as I do some mods to the engine and will need larger tubes.
Old Mar 9, 2008 | 08:24 PM
V-Rod's Avatar
V-Rod
another question can I get away with the uncoated ones for 300 less since I will want to trade up to stahl in a year or so anyway. or will they put off too much heat?
Old Mar 9, 2008 | 08:34 PM
BigBlockTank's Avatar
BigBlockTank
That should be an easy answer. Save your money and buy the "end result" when ya got the money!!!!
Old Mar 9, 2008 | 09:06 PM
V-Rod's Avatar
V-Rod
It would be if I didn't have a 425HP SB coming next to swap for my L-48 I don't want to hook that up to the old stock manifolds. So after the costs of the Engine, March kit, and BTO 2004r l2. Like the federal government I am into deficet spending but unlike the Gov. I can't keep printing money. I've got an Idea maybe I could get a Gov. grant to study the how impact of Corvette enthusist's spending on the national economy and how extra tax breaks for us would go right back into the economy thus heading of a ression.
Old Mar 9, 2008 | 09:24 PM
thrilher's Avatar
thrilher
vrod, atleast your aware..most arent
Old Mar 9, 2008 | 09:48 PM
Little Mouse's Avatar
Little Mouse
The GREAT LEECH never has a problem if it can't print money It will
eventually raise taxes LEECHING the money off its citizens. Then
when it screws up spends that money on who knows what kind
of BS the GREAT LEECH just comes back again for another LEECHING
of its citizens. A regular blood sucking leech you can pull off yourself.
The GREAT LEECH you can never get it off you it sucks your money
all your life and if you do well enough for your family The GREAT
LEECH will even come into your casket LEECH some more money off
you so your kids can't get it.
Old Mar 10, 2008 | 12:18 AM
62C1's Avatar
62C1
I've been running the Hedman side exit headers on the race car for several years now. The car performs fine with them. I did wrap them with header wrap. They've gotten banged around a bit with several off course excursions and still are holding up well. Stahls or Hookers would be nice but it's easier to take banging up a set of Hedmans rather than the high dollar headers.
Old Mar 10, 2008 | 03:53 PM
68/70Vette's Avatar
68/70Vette
They are really inexpensive. I think I paid $180 for mine. As far as I can tell they were of good quality. Had mine Jet-Hot ceramic coated.
No problem with fitting really. Even though my ZZ4 exhaust ports are a little higher than the original engine, the headers still cleared the frame. One of the tubes was about 3/8 inch underneath the grease nipple on the idler arm. Replaced the grease nipple with a 90 degree unit and slightly dimpled the header tube so the grease gun would fit.
To Headman header?
