New engine/transmission-HELP!
Old Mar 11, 2008 | 02:52 PM
auburndan's Avatar
auburndan
Default New engine/transmission-HELP!
I've got a 76(automatic) and just installed a brand new GM 350/290HP engine. As soon as I try to break in the engine the transmission gives out(clutch burned out according to mechanic). Is this normal? Also, the mechanic tells me he can get a rebuilt transmission for $650. Does anyone know of a better deal out there? Also, I'm already over budget for getting this car in tip top shape(getting married this fall and want to get my car expenses out of the way before then) and need to know what else to expect. What else can go wrong? Will the rear end go out on me next or what? Any advice would be appreciated.
Thanks,
Dan
Old Mar 11, 2008 | 02:59 PM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
$650 doesn't sound like very much for a "well" rebuilt 350 tranny. Is there a warranty with it? As for what goes wrong next, that is anyone's guess. However, you say the car is in tip top shape. If that's true, you shouldn't have any major trouble with it for quite some time.
Old Mar 11, 2008 | 03:08 PM
Merlinhaggard's Avatar
Merlinhaggard
I think you can find a turbo 350 for a couple of hundred.. Ebay..
Old Mar 11, 2008 | 06:01 PM
auburndan's Avatar
auburndan
I'm "trying" to get the car in tip top shape. Here's what's been done so far: All front end components have been replaced. New tires,trim rings, brakes,frame supports and bushings,new exhaust,replace all floors, new carpeting,new paint about 2 years old with matching pin striping. New wiring, all new whaether striping and molding. Now I've got the new engine put in, and am about to put in a new transmission. If something else on this car breaks I'm gonna go crazy. Any suggesstions on the transmission to get?
Old Mar 11, 2008 | 06:34 PM
auburndan's Avatar
auburndan
What does everyone think about this transmission?
: TCI
Product Line: TCI Street Rodder Transmission Packages
Part Type: Automatic Transmission Packages
Part Number: TCI-311038P1
Transmission Included: Yes
Case Material: Aluminum
Case Finish: Silver
Valve Body Style: Automatic
Trans-Brake Included: No
Transmission Dust Cover Included: No
Pan Type: Deep cast aluminum
Dipstick Provision: Yes
Dipstick Included: Yes
Fluid Fill Location: Case
Transmission Fluid Included: Yes
Transmission Fluid Type: TCI RTF
Transmission Fluid Quantity: 12 qt.
Transmission Shield Built In: No
Flexplate Shield Built In: No
Electronic Transmission Controller Included: No
Torque Converter Diameter (in): 12 in.
Torque Converter Included: Yes
Advertised Flash Stall Rating (rpm): 1,700 rpm
Lockup: No
Furnace Brazed: Yes
Transmission Cooler Included: Yes
Cooler Construction: Tube and fin
Cooler Material: Aluminum
Cooler Finish: Black painted
Quantity: Sold as a kit.
TH350 TRANSMITION PACKAGE
Check to make sure this part fits your application
Complete transmission packages from the professionals at TCI Automotive.
Perfect for a mild daily driver or street rod, these TCI Street Rodder transmission packages give you all of the components necessary to install a new transmission. They include a TCI triple transmission with an installed shift improver kit to allow firmer shifts, yet retain the fully automatic features of the valve body. TCI Street Rodder transmission packages feature a TCI precision torque converter, a universal transmission cooler, and three gallons of premium TCI RTF transmission fluid.
Old Mar 11, 2008 | 06:55 PM
JustinD's Avatar
JustinD
PM Sent
Old Mar 11, 2008 | 10:27 PM
Merlinhaggard
I bolted a 468 BBC right at 400 HP up to a Turbo 350 and ran the dog crapp out of it and never had a problem. I wouldnt waste the money. Of course I have bigger fish to fry on my project, llike paint.. Anyway my 2cents..
Old Mar 11, 2008 | 10:39 PM
Artsvette73's Avatar
Artsvette73
Go Overdrive forget the thm350
Old Mar 11, 2008 | 11:32 PM
auctionman256's Avatar
auctionman256
try a 4L60
Old Mar 11, 2008 | 11:37 PM
1981Z06Vette's Avatar
1981Z06Vette
Originally Posted by auctionman256
try a 4L60
Be careful with that one though...4L60 is just the newer name designation for a TH700R4; there are no real differences. They were available in 93 only (In F-bodies, not sure about other apps), and use a TV cable. The 94-newer 4L60E is electronic, and will need an expensive contol box to run (unless you are running an LT1 or LS motor, in which case the PCM would operate it).
To New engine/transmission-HELP!
