Fuel Injection recommendations
Old Mar 12, 2008 | 04:36 AM
toddlaj's Avatar
toddlaj
Default Fuel Injection recommendations
I want to ditch the carb and go fuel injection and stay below $2000. I have a 76 automatic L48 split exhaust and a 650 carb. No known changes to the engine other than the carb. What system/ company would you guys recommend.
Old Mar 12, 2008 | 05:41 AM
1981Z06Vette's Avatar
1981Z06Vette
Its slightly over your stated budget, but its still the way I would go:
http://store.summitracing.com/partde...5&autoview=sku
Though, on second though, it may not fit under your stock hood...I'd check first.
Old Mar 12, 2008 | 07:06 AM
vetteguy75's Avatar
vetteguy75
LA Events Coordinator
Have you looked into this system from Mass-Flow" Looks interesting...
http://www.massfloefi.com/
Old Mar 12, 2008 | 07:30 AM
vettfixr's Avatar
vettfixr
I was just looking through the latest issue of Popular Hotrodding magazine this morning and they had a short take on a new EFI system from FAST. It's a throttle body system but according to the article you need no laptop or fancy software to install it and everything you need is included in the kit. It fits 4 barrell intakes and supposedly is very performance oriented. The street price they quoted was about $1900. I went on their site to see if it was listed but didn't find anything there. You may want to give them a call to find out more.
Old Mar 12, 2008 | 08:03 AM
markdtn's Avatar
markdtn
Tuned Port off a 85-91 C4 or 86-92 F-body. Do a search for my username and TPI and you should find my "primer". DrJay has also done an install guide recently.
Old Mar 12, 2008 | 08:52 AM
Brandywine's Avatar
Brandywine
Try Jims Performance for C4 TPI's and parts... around your budget
http://www.jimsperformance.com/
Old Mar 12, 2008 | 09:44 AM
timbo79's Avatar
timbo79
This is who I used.. Ken is a good guy and the system is great.
http://www.firstfuelinjection.com/products.htm
RObie Customs sells the same thing, but if you want it powdercoated, it cost alot more. (could also do it yourself)
http://store.robiecustoms.com/ficoinkit.html
I personally would stick with Ken as he is in your budget and it is a compete kit.. no searching around for parts.
Throttle body on the first is huge as well!
Good Luck!!
Old Mar 12, 2008 | 11:19 AM
73-84 IMSA Widebody's Avatar
73-84 IMSA Widebody
Take a look at www.kinsler.com the site itself is a how to manual and the staff will talk about/help with any system you are looking at. Send them an email telling them what your looking to do and how much $.
They are experts in any and all FI systems
Old Mar 12, 2008 | 11:24 AM
breathial's Avatar
breathial
I'd suggest you do it yourself! Check HERE.
Not only will you learn a LOT about EFI, but you'll also be able to pick and choose whatever setup you want to use...
Better to DIY, and keep as much $$$ in your own pocket as possible.
Old Mar 12, 2008 | 04:48 PM
Bee Jay's Avatar
Bee Jay
I just installed the Holley 950 TBI. I'm still dialing it in, but it's running. Once I get it all sorted out, I'll post.
Bee Jay
Old Mar 12, 2008 | 05:12 PM
gyopp's Avatar
gyopp
I have this and while I thnk it is a really cool setup there is no way it is going under a stock hood. It has less than 1" of clearance under my L88 hood
Old Mar 12, 2008 | 05:43 PM
chevjyd's Avatar
chevjyd
5th Gear
Have you looked at retrotekspeed.com? They have a setup that looks like a holley for $2100. Dont know of anybody that has it, but its a cool concept.
Old Mar 12, 2008 | 10:58 PM
Fast81's Avatar
Fast81
Holley Pro-Jection 2
Holley Pro-Jection 4
Holley Commander 900
Edelbrock port injection
Take your pick
Old Mar 12, 2008 | 11:20 PM
33Chevy's Avatar
33Chevy
Think about the GM 85-92 TPI system..a bunch of them out there (I have a few in my barn for future projects).
Here is a link to the "Chevy TPI Fuel Injection Swapper's Guide: 1985-1992 TPI Systems Manual" Tells you what you need and how to do it. The book is also on ebay etc.
http://www.themotorbookstore.com/che...injection.html
There is a member or two out there with them on their C3's.
Old Mar 13, 2008 | 09:18 AM
rclinton's Avatar
rclinton
Veteran: Marine Corps
I may get flamed but interesting set up from Professional products.
http://www.professional-products.com/efiSystems.html I dont have it or know any other info than what is on there website, but its a bolt on, complete system that should fit under the hood.
Old Mar 13, 2008 | 10:00 AM
L88Plus's Avatar
L88Plus
MSD is getting into the market, starting with LS stuff. Once they get that ironed out, they'll probably be one of the better and more user-friendly stuff. BigStuff is owned by the guy that did most of FAST's and a few other companies setups, he's pretty much the guru in the field.
Old Mar 16, 2008 | 01:05 AM
73ls1's Avatar
73ls1
A few months ago Corvette Fever had a story about swapping a throttle body to a 1977 l48. They used junk yard parts and I think it cost around $500 to do it.Chris Petris wrote the article. Ihave the issue and I will try to find it.Just do what I did and install a LS 1.Charlie
To Fuel Injection recommendations
Old Mar 16, 2008 | 09:54 AM
Guru_4_hire's Avatar
Guru_4_hire
Cruise-In IV Veteran
Cruise-In V Veteran
Kinsler may be experts but their setups are $$$$$$$$$
Old Mar 16, 2008 | 10:35 AM
bruced267's Avatar
bruced267
I did a TPI off a late model vette, easy swap looks good, you could keep it at or under $2000 if shop carefully! make sure you get a good and complete manifold! the litte parts add up fast! Do your research first! Also try Street and performance
www.hotrodlane.cc
Old Mar 16, 2008 | 12:59 PM
mrvette's Avatar
mrvette
www.hotrodlane.cc
S&P is high dollar too, you can get a TPI system complete with injectors for less than 300 bux these days.....with tbody too....stock that is.....hotrod parts will run more...you can pull 300 hp outta that thing with a cam and little else....the total install should be less than 700 bux, IF YOU DO YOUR OWN WIRING, you buy some expensive harness rather than solder a few wires yourself, and you going to spend 300++++++ bux on the harness alone, which IMO is a total RIP....
the computers go for some 10-50 bux in junkyards...the one you need is #1227730.....the computer harness ends are common to lots of engines....the sending units are common to most any 3.1 in the junkyards all over the place....
the chip is available from tuners....Alvin, Jeremy, Ernie....
