Luggage Rack
Old Mar 12, 2008 | 11:35 AM
tommyleea's Avatar
tommyleea
Default Luggage Rack
I was planning on removing my luggage carrier to do some polishing. It looks straight forward, but I know better. Are there going to be any surprises once I remove it, or will it just go back on with no problem? Do I need new hardware beforehand? Thanks.
Tommy
Old Mar 12, 2008 | 12:43 PM
Binnie77's Avatar
Binnie77
Unless, the screws are corroded in the well nuts you should be OK. Most of the well nuts I have seen are brass so I expect yours should come out fine. You should be able to use the same well nuts without a problem. If you have to replace any, push the old ones down through and they will work their way to the ground at some point
Old Mar 12, 2008 | 01:39 PM
7T1vette's Avatar
7T1vette
Piece-of-cake, if you have stainless steel hardware. Just put the hardware in a can until you decide to reinstall it.
Old Mar 12, 2008 | 11:42 PM
tommyleea's Avatar
tommyleea
Thanks for the info guys. Seems like a nice weekend project. Cheers
Tommy
To Luggage Rack
