fuel pump question
Old Mar 12, 2008 | 08:54 PM
BassCat's Avatar
BassCat
Default fuel pump question
I replaced the heater hoses on my 77 Vette today, and after installation, I got under the car to check for leaks. With the engine running, I happened to notice that my fuel pump moves in and out about a quarter of an inch. I guess it's the pumping action on the inside that causes this. It's probably the original 31 year old pump. Is this normal to see the movement from the outside, or is something worn out and needing replacement?? It's not leaking, and the bolts are tight. When I say it's moving, I mean it has a rythm type movement to it, while the engine is idling. Thanks,
Kenny
Old Mar 12, 2008 | 09:05 PM
L82shark's Avatar
L82shark
St. Jude Donor '08
I really dont think it should be moving..... You are sure the bolts are tight? Is the car named Christine by chance?
I would probably pull it and replace it. Just my .02
Old Mar 12, 2008 | 09:48 PM
BassCat's Avatar
BassCat
Thanks shark, yea this thing probably is a little possessed. I went down and checked it again, and the pump feels tight. With the engine running, it does actually move though. It's like a pulse type movement. I'll recheck everything tomorrow when it's light out. The car runs fine and I don't see a leak anywhere, so it must be OK. I just never had noticed the movement before.
Kenny
Old Mar 13, 2008 | 09:00 AM
BKbroiler's Avatar
BKbroiler
There is no way your fuel pump should be moving. It is either loose or cracked.
Old Mar 13, 2008 | 08:17 PM
BassCat's Avatar
BassCat
Well, after finally getting under the car with some good light and a wrench, I found the problem. The two bolts holding the pump on WERE loose. Tightened 'em down and no more wobble. Thanks guys.
KC
Old Mar 13, 2008 | 09:39 PM
kdf1986's Avatar
kdf1986
Good thing you found that when you did. Can you imagine one of them coming out when you were driving? While you were there did you check the condition of the hoses. If they are getting old and cracked now would be a good time to replace them.
kdf
Old Mar 14, 2008 | 06:17 AM
BassCat's Avatar
BassCat
Matter of fact I did go ahead and replace the lines coming off the fuel pump while I was under there. They were probably the original lines. I've only had the car a few months, and everytime I start tinkering with it, I find something else that needs replacing. It's getting there though. Getting better everyday. The car had sat unused for 5-6 years before I bought it and the lady that owned it before me obviously did nothing but drive it. I've got a list of new parts a mile long already installed on it, and it's just now starting to feel reliable to me. I guess all of these cars are a work in progress. Fun though. Thanks for the advice on the fuel lines.
KC
Old Mar 14, 2008 | 08:17 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
You da man...solved the problem yourself.
Old Mar 14, 2008 | 01:08 PM
BKbroiler's Avatar
BKbroiler
Don't I get any credit? I suggested that the bolts were loose.
To fuel pump question
