solid roller lifter adjustment
Old Mar 12, 2008 | 10:29 PM
chevymans 77's Avatar
chevymans 77
St. Jude Donor '05-'06,'11,'13-'14,'16,'18,'19,'24, '25
Default solid roller lifter adjustment
cam card says .024 hot were to set cold? resetting after 500 miles.
Neal
Old Mar 12, 2008 | 10:53 PM
MotorHead's Avatar
MotorHead
From: Who says "Nothing is impossible" ? I've been doing nothing for years.
Drive it 5 more miles and set hot
I usually only go 2 thou smaller on both intake and exhaust You could try .020" and then set them hot
Old Mar 12, 2008 | 11:00 PM
Retro78's Avatar
Retro78
Aluminum heads = subtract .002 as Motorhead said
Iron = add .002
These are just for an initial settings to get you going. Reset them hot as per your cam card.
Old Mar 12, 2008 | 11:41 PM
chevymans 77
thanks for the replys, I'll start there and than adjust hot. gotta go get new gaskets before I can run it.
Neal
To solid roller lifter adjustment
