Rear sway bar installation question
Old Mar 13, 2008 | 12:32 AM
1Fordman's Avatar
1Fordman
Default Rear sway bar installation question
I purchased a VBP rear sway bar kit a few months ago and decided to install it. Problem is the installation instructions are no where to be found. I found the threaded holes in the frame for the sway bar bushing brackets to attach to but can't figure out where the brackets for the links attach to.
Also does the bend in the bar face up or down when bolted to the frame?
I would sure appreciate any info or even photos of an installed rear sway bar.
Old Mar 13, 2008 | 12:35 AM
Bowerss2's Avatar
Bowerss2
I have this same question
Old Mar 13, 2008 | 11:30 AM
BB68Vett's Avatar
BB68Vett
Use the advanced search tool to find similar threads. The brackets attach to the back of the rear trailing arm using the two holes that held the stock rear sway bar bracket. The long rectangular piece with the large hole on one end for the bushing and two smaller holes for the bolts goes into the back of the trailing arm and is held in place by two bolts inserted from the top of the trailing arm. I believe the bend in the bar will go up (but I am not sure). Once again, search the archives, and if you still can't find anything, I can take a picture and post it tonight for you. Just let me know.
Old Mar 13, 2008 | 11:46 AM
r44s's Avatar
r44s
I would appreciate seeing a picture. Thanks
Old Mar 13, 2008 | 12:04 PM
suprmnate's Avatar
suprmnate
4th Gear
I had to drill 2 holes in the training are to mount the rectangle plate. Also, my sway bar had no bend. keep in mind two things; 1 the brackets and sway bar may be very close to the inside of the rear tire. I have 275/50-15's and it is tight. 2. Access to the top of the leaf spring bolt is pretty much impossible once the bracket is installed.
Old Mar 13, 2008 | 12:22 PM
ctgene's Avatar
ctgene
Banned Scam/Spammer
I have the sway bar to install yet that I purchased from VBP, but I remember they have an instruction tab on there web page...Don't remember if they cover the sway bar install though...if nothing else give them a call they have been very helpful with me when I call...I'm installing there performance plus kit on my '79 and called them 3,4 times and they answer my questions each timel...can't wait to get it all back together and give it a test drive.
Old Mar 13, 2008 | 12:32 PM
sperkins's Avatar
sperkins
I too had to drill the holes for the plate. Here are the best pics I have right now:
Old Mar 13, 2008 | 01:09 PM
ptroxx's Avatar
ptroxx
From: Henderson Nv-Rohnert Park/Sonoma C o. ca/born in NY Rockaway Beach.
On my 77 the holes were already there.....just had to bolt everything togerther..Also I had the break lines in the way a little.. Just be careful
Old Mar 13, 2008 | 01:24 PM
ptroxx's Avatar
ptroxx
What size is your bar...
You might want to read thru this
http://forums.corvetteforum.com/show....php?t=1954158
Old Mar 13, 2008 | 09:42 PM
1Fordman's Avatar
1Fordman
Thanks for the photos, they confirmed the location I was thinking was correct. The holes are there and the blue beast has a 1-1/8" front bar and will soon have a 3/4" rear bar. Well back to the garage for more abuse (to me, not the beast!).
I'll try the rear bar and if the handling sucks, it will come off. There are a couple of recent and interesting threads on sway bars.
Old Mar 13, 2008 | 09:49 PM
timbo79's Avatar
timbo79
I am in the process of adding a 1 1/8 front and a 5/8 rear. my car is a bit lowered though Going to Thunderhill in April with it
Old Mar 13, 2008 | 09:53 PM
VIPERBARON's Avatar
VIPERBARON
From: Guantanamo Bay, Cuba (home in Colorado Springs)
I put the bend UP.
Old Mar 13, 2008 | 10:38 PM
ptroxx's Avatar
ptroxx
Yeha I can tell you a story aboout my new rear sway bar.... I put on the same rear bar but bibn upgrade the front yet and man....WOW what aride....
Im not sure if you know where the 37 and the 116 meet in sonoma...but I did a 900 yes that 2 1/2 turns making that turn last week.... man that *** end kicked out on me.. i almost got it straight but it stalled on me...LOL
so be careful when you first take it out......Just a little FYI...
Old Dec 5, 2009 | 01:32 PM
flynhi's Avatar
flynhi
I strongly advise against using a 3/4" rear bar unless you have oversized rear tires.
The bar is twice as stiff as a 5/8 and essentially converts the Independent Rear Suspension into a straight axle. This means that you have little or no camber change in a turn. this means that you lose tire patch contact which means loss of traction, a loose rear end, break away and possible spin.
This happened to me several times before I figured it out and switched back to a 5/8" rear bar with 17" wide tires. Now my 71 rides on rails.
Old Dec 5, 2009 | 02:30 PM
Cleon's Avatar
Cleon
I have a 1979 and installed the VBP suspension with rear sway bar. The threaded holes
are on the bottom of the frame next to the rear body mount bracket. Improved handling
a lot.
Old Dec 5, 2009 | 05:03 PM
GUSTO14's Avatar
GUSTO14
This is one of the better pictures I have of mine, similar to some of those above, but it doesn't show it as clearly.
The bend should go up as it crosses over top of the spare tire carrier. It will actually fit either way, it will just press against the top of the spare tire carrier if you put the bend down.
Good luck... GUSTO
Old Dec 5, 2009 | 05:37 PM
Lt1er's Avatar
Lt1er
Which event are you going to?
Old Dec 6, 2009 | 12:13 AM
pauldana's Avatar
pauldana
Just installed mine today and a new larger one up front also... Wow... its a roller coster on rails!! you will love it...
I also have the #500 front springs cut 1/2 coil, rear carbon fiber, Bilstene Sports all around, and gone all poly.... wheels and tires next, but man, what a difference...
I put my bend down like the front sway bar... but I do not carry the spare.... AAA
Old Dec 6, 2009 | 12:59 PM
larryg3's Avatar
larryg3
i put in my VBP street and slalom last winter and boy what a difference i loved it ON RAILS!!!
by the way i put mine in bend up!!
To Rear sway bar installation question
