intake question
Old Mar 14, 2008 | 05:32 PM
77owner's Avatar
77owner
5th Gear
Default intake question
i have a recently aquired 77 w/350 got headersand new exhaust going in and was wondering about changing the intake or maybe some other things that arent gonna bankrupt me or warrant tearing the engine completely down,anybody have suggestions on maybe an intake change and or carb,or maybe just intake what to look for what to use?combinations of things??open to suggestions.didnt want to replace the cam ,edlebrock was saying using their carb andintake would mabe need a hood change.what performance changes would or could i expect from this??not building a drag racer but would like to sqeeze a little more out of what i hav presently which is stock pretty much.thanks
Old Mar 14, 2008 | 05:38 PM
couperdecar's Avatar
couperdecar
personally - carb arn intake are going to make minimal difference. You need different heads to get the compression up and to flow better. Big Big difference there. THEN a carb and intake.
Old Mar 14, 2008 | 06:18 PM
marshrat99's Avatar
marshrat99
How about a Weiand (sp?) 142 super charger on top of that bad boy?
Old Mar 14, 2008 | 06:21 PM
NHRalph's Avatar
NHRalph
You already have the headers and exhaust, is the exhaust duals? If so, a good intake swap and you will notice the difference. You can buy better heads but unless your going to change the cam, don't bother with heads. you motor will still perform a lot better then stock. Those heads although restrictive still was used on some pretty good high horsepower mills.
Old Mar 14, 2008 | 09:56 PM
straub18045's Avatar
straub18045
would take those heads and have them flowed at the speed shop, cheaper than new heads and gobs more power. airgap intake and proper tuned q-jet will make for a killer combo on a small wallet. make sure your spark and fuel curve are on and its like night and day
-you are limited by the cam though
Old Mar 15, 2008 | 03:08 PM
77owner's Avatar
77owner
5th Gear
thanks i dont know exactly what I'll do yet but i appreciate all the input
Old Mar 15, 2008 | 03:13 PM
77owner's Avatar
77owner
5th Gear
so did you change your intake and it made a noticeable change?some said dont bother changing intake and carb that i wouldnt make difference.i just gotta find a combination that will work and its gotta smog for ca.i was considering edelbrockcarb and intake but got to find solution for stock air cleaner base to work and may have to change hood for clearance if i do.dono yet
To intake question
