Brake fluid separated??
Old Mar 15, 2008 | 10:05 AM
chrisd0729's Avatar
chrisd0729
Default Brake fluid separated??
Tried bleeding the brakes last night to fix a low pedal and the fluid was separated with darker/cloudy fluid on the bottom and crystal clear fluid sitting on top. I thought it was water at first so I dipped my finger in and it was actually brake fluid. When I poured some fresh fluid in for bleeding, the MC looked like I poured vinegar into oil with a bunch of small oil bubbles in the vinegar. It then separated again and rested with the clear on top.
Planning to buy fluid today, syphon and replace all that's in the master cylinder and then bleed out the rest through the bleeders.
Any idea why it's separating? Will bleeding it all out clean the system enough? Also, is it safe to assume this is the reason for my low pedal? It stops great and the pedal is hard but, not hard until the lower 1/2 of the pedal motion.
I've only had the car a little over a year and not sure what fluid was in there before. Would this happen if the PO used DOT5 and I just added DOT3?
Old Mar 15, 2008 | 10:11 AM
Jud Chapin's Avatar
Jud Chapin
St. Jude 15 Year Donor
St. Jude Donor '11 thru '25
Do you know how old the fluid is? As a general rule, it should be flushed (replaced) every 2 years or so. Just bleed it out of each wheel caliper until it comes through clear and then see how the pedal feels. Brake fluid takes on water over time which reduces braking ability. I use DOT 4 which has less propensity for water.
Old Mar 15, 2008 | 10:20 AM
SIXFOOTER's Avatar
SIXFOOTER
DOT 3 and 4 are Hydroscopic liquids that are alchohol based and they do absorb water over time. You have the right plan, syphon it out or soak it out with a rag, then refill and bleed.
I am a big fan of DOT5 ever since my first brake fade caused me to impact the back of a pontiac on my bike at about 40mph, it takes a little care to clean, flush and bleed, but IMHO worth it.
Once its in there it will not give you any problems
Old Mar 15, 2008 | 10:54 AM
7T1vette's Avatar
7T1vette
Maybe someone installed silicone brake fluid in the system with regular brake fluid already in it. In any event, you will have to purge the entire system and refill with the type of fluid you want in it. If you take it to oil change place for maintenance, you need to tell them which type you put in your brake system. If you paid for "full service" [I thought that meant they just charged you more], they could have topped-off your M/C with the wrong stuff.
Old Mar 15, 2008 | 10:56 AM
Duke94's Avatar
Duke94
Brake fluid doesn't separate unless it's mixed with some other type fluid. In any event, flush, flush, flush. and hope someone didn't dump transmission fluid in it.
Old Mar 15, 2008 | 10:59 AM
Mike Ward's Avatar
Mike Ward
Yes.
Old Mar 15, 2008 | 11:06 AM
Mike Ward's Avatar
Mike Ward
DOT 3 and 4 are glycol based, not alcohol. If you had brake fade , it was not caused by incorrect fluid type. The difference in boiling point between DOT 4 and DOT 5 is only 54 degrees F. No street driven vehicle comes anywhere near the boiling point of a modern brake fluid.
Old Mar 15, 2008 | 11:13 AM
S489's Avatar
S489
new dot 3 & dot 5 after some time to separate:
Old Mar 15, 2008 | 11:20 AM
S489's Avatar
S489
same jar but shaken to mix the two:
To Brake fluid separated??
