Sidepiper , the reason I asked is thta I had a short squeal that turned out to be the bushing on the front of the rearend hsg. where it mounts to the frame.
With your sound lasting 30 seconds I suspect a bearing is starting to go bad.
Maybe if you raise both rear wheels and turn the tires you may be able to isolate the location
David
Thanks, that might be it, Ill raise it up tomorrow.
