Motor Mount Spacers
Old Mar 16, 2008 | 08:07 PM
SCARA451's Avatar
SCARA451
Default Motor Mount Spacers
Could someone please tell me the purpose of the "V" shaped spacers that mount underneath the motor mounts on a Big Block. They were under the mounts on my original 1971 454ci. with A/C. I had read they were only on 427's with A/C. Thanks...Doug
Old Mar 16, 2008 | 08:13 PM
S489's Avatar
S489
i researched into this when changing from sb to bb and could find no "official" reason other than the bb a/c cars req'd them. someone told me it was to create clearance for something-didn't know for what. my combo didn't seem to need them; maybe someone else has new news . . .
Old Mar 17, 2008 | 08:38 AM
vettfixr's Avatar
vettfixr
The only thing I can think spacers would do is raise the engine relative to the frame. This in turn would raise the fan in regard to its position within the fan shroud. I guess its possible that it was for aligning these components properly.
Old Mar 17, 2008 | 10:29 AM
DRIVESHAFT's Avatar
DRIVESHAFT
From Dr. Rebuild's web page-
66-74 BIG BLOCK with AC MOTOR MOUNT SHIM These Cadmium plated 1/8" thick steel shims, mount between the block & the motor mounts. They are essential to keep the carb float bowls level on all Air Conditioned Big Blocks. 2 reqd.
Old Mar 17, 2008 | 12:35 PM
S489's Avatar
S489
wonder where DR Rebuild found that info??
Old Mar 17, 2008 | 02:55 PM
TheSkunkWorks's Avatar
TheSkunkWorks
From: Graceland in a Not Correctly Restored Stingray
"essential" ??
Old Mar 17, 2008 | 05:15 PM
S489's Avatar
S489
Originally Posted by TheSkunkWorks
"essential" ??
not for me; worked without; was just curious
To Motor Mount Spacers
