Power steering lines question
Old Mar 17, 2008 | 06:44 PM
wiseman79's Avatar
wiseman79
Default Power steering lines question
Should you use teflon or similar when installing power steering hoses? I swapped out my valve last night and the hoses are leaking at the valve now. There was no teflon used before and my gut says no, but was wondering if this was an acceptable thing to try prior to buying new lines. The existing lines appear in good shape, what are the odds I buy new hoses and they leak too- i.e. something wrong at the valve?
Old Mar 17, 2008 | 06:56 PM
kansas123's Avatar
kansas123
Here's a bump, I am planning on replacing mine in very near future............
Old Mar 17, 2008 | 07:16 PM
jnb5101's Avatar
jnb5101
teflon is not needed on the compression fittings. check the seats on the valve for nicks or other damage. use a q-tip and a good light. did all the old hoses leak? bubba may have had 20 inch arms and over torqued the fittings.
jeff
Old Mar 17, 2008 | 07:21 PM
champs65's Avatar
champs65
jeff
Flared fittings don't need teflon.
Old Mar 17, 2008 | 09:26 PM
wiseman79's Avatar
wiseman79
Thanks that's what I thought. Luckily I'm minutes from Zip's so will go by and get new hoses tomorrow. No, the old hoses didn't leak, but my experience with these things is once you disturb old parts, gremlins will emerge. Kansas, if I had it to do over, I'd of just bought the kit, with hoses, valve, and cylinder and get the whole system done at once. I don't know about you, but the frustration of another trip under the car and another Saturday morning lost is more costly than the extra parts. Not to mention I drove the car to work today thinking all was well, only to find a puddle under the car at lunch time.
Old Mar 18, 2008 | 09:25 PM
wiseman79's Avatar
wiseman79
Ugh, new lines, same leaks. I'm returning the valve tomorrow. The old valve and old hoses didn't leak, new valve and old hoses do, new valve and new hoses do, I'm noticing a pattern.
Old Mar 19, 2008 | 06:35 AM
Teppist's Avatar
Teppist
Cruising
I've replaced power steering lines without add teflon and works fine.
Old Mar 19, 2008 | 09:56 PM
kansas123's Avatar
kansas123
Rats, sorry to hear you are having all this trouble. Maybe (another) new valve will solve the problem. I am asking for what I get if and when I do anything with my system, as it has been empty for I don't know how long. It begs for complete replacement, but I figure I have nothing to lose by starting with just hoses; everthing else seems okay. Figure I might be in for a nice fluid bath at the worse.
Best of luck on your system.
Old Mar 19, 2008 | 10:00 PM
rponfick's Avatar
rponfick
Only advantage to using teflon is to reduce friction on the threads and get all your torque on the flare seat itself. It's use comes in handy sometimes on gas line fittings, brake lines and any other type of flare connection. Only reduces friction, not sealing.
Ralph.
Old Mar 19, 2008 | 11:52 PM
no2pencel's Avatar
no2pencel
Ralph.
I disagree. The primary purpose of Teflon tape is to seal pipe threads, not distribute torque.
Old Mar 20, 2008 | 09:54 AM
stingraydriver74's Avatar
stingraydriver74
i had the PS leaking blues too on my '74....replaced the three hoses with threads on each end, didn't solve the problem. replaced the main hose with the clamp on one end... problem solved it was also dripping out of the grease fitting on the bottom of the valve, just slipped a vacuum plug over it and presto! potty trained vette.
Old Mar 20, 2008 | 10:51 AM
rponfick's Avatar
rponfick
No2pencel, I stand corrected, the primary purpose or teflon tape is the seal pipe threads.
I only meant to say that its slickness can be helpful in reducing flare joint thread friction.
Ralph.
Old Mar 20, 2008 | 01:37 PM
wiseman79's Avatar
wiseman79
Problem fixed. I swapped the valve. I compared the faulty valve with the other new one. The brass fitting inside the valve on the ram output sides were recessed deeper than on the good one. I tried the hoses on both out of the car and what was happening was I could thread the hoses into the bad one until I was out of threads, and it wouldn't reach all the way to mate with the brass fitting inside the valve. The good one only went several turns in then contacted and sealed. Zip as usual was great and gave me no grief on the exchange. Thanks everyone.
To Power steering lines question
