100 Amp Alternator
Old Mar 17, 2008 | 08:32 PM
kansas123's Avatar
kansas123
Default 100 Amp Alternator
What if anything would a 100 AMP internally regulated alternator do for a stock '72 350 auto with A/C? Thanks.
Old Mar 17, 2008 | 09:07 PM
wombvette's Avatar
wombvette
Nothing unless you need that much for some reason.
Old Mar 17, 2008 | 09:49 PM
Ironcross's Avatar
Ironcross
However you can get a 94 amp alternator with the same case measurements as a direct no fit for about the same price as your 55 or 63 and no one will know the difference. Or have your old numbered cases filled with the 94 internals.....
Old Mar 17, 2008 | 11:41 PM
7T1vette's Avatar
7T1vette
Nothing whatsoever....unless you've installed a massive stereo system in the car.
Old Mar 17, 2008 | 11:44 PM
SIXFOOTER's Avatar
SIXFOOTER
or high power lights, electric fans, mood lighting.....
gavanm01's Avatar
gavanm01
Our community has had some intermittent power problems. Maybe we could hook you up to the grid when we brown out?
Old Mar 18, 2008 | 02:46 AM
vho69's Avatar
vho69
mood lights were the heck do you have any room in a vette to need mood lights
Old Mar 18, 2008 | 06:57 AM
gingerbreadman1977's Avatar
gingerbreadman1977
i think its a good idea.i run a 120 amp constant alt ... keeps your lights nice and bright. and if you put in thermo fan or stereo and all that the power is there.
Old Mar 18, 2008 | 07:28 AM
Gordonm's Avatar
Gordonm
What you need to do is add up all your power needs and then go slightly over what amps you need. No need to go overkill unless you have future plans for massive power needs. Your 60 amp alt will do just fine unless you have added more power drains such as electric fans or a huge stereo system. I upped my 43 amp alt. to 80 amps in the stock case. I have added electric fans and a CD ignition which added about 35 amp draw at max to the existing system. No problems at all running this way.
Old Mar 18, 2008 | 07:58 AM
joefloyd's Avatar
joefloyd
If I install a 100 amp in an 80 do I need to change the wire feed to it? I don't plan to add to the stock load.
Old Mar 18, 2008 | 08:37 AM
Gordonm's Avatar
Gordonm
If you are not putting any more load on it you should be fine with the stock wiring. I'm running the stock wiring with my 80 amp one with no problems.
Old Mar 18, 2008 | 09:30 AM
wombvette's Avatar
wombvette
Sort of depends on where you draw that current from. If you draw that current from inside the car through the original bulkhead connection, you will develop a serious case of Air Car Itis.
Old Mar 18, 2008 | 09:34 AM
bigvette1's Avatar
bigvette1
Default Alt Suggestion
Ok, what suggestions do you have for brand of a 100 or 120amp alt that is a direct bolt in? Wiring changes needed for higher amp o/P?
Old Mar 18, 2008 | 10:02 AM
Ironcross's Avatar
Ironcross
google '94 amp GM alternator' and you can find the answer to a simple bolt in alternator without any hassle. Should be available at most parts houses.
Lester number is possibly {7294-12} probably under $50.00
Old Mar 18, 2008 | 12:37 PM
kansas123's Avatar
kansas123
Thanks, this is what I was curious about. This car only has stock radio, air conditioning, PS & PB, so I am tempted if it will brighten the lights. I just didn't want to chance doing any damage. This is what brought this all about:
http://cgi.ebay.com/ebaymotors/69-70...em230233259030
Old Mar 18, 2008 | 12:42 PM
Gordonm's Avatar
Gordonm
No harm in having enough power for the lights but headlights will wear out. If you have old headlights they will not be as bright as a new set will. They do wear out. I put in a new set of halogen bulbs a few years ago with the stock 43 amp alternator and the lights were a whole lot brighter than the old headlights. After I put in the higher amp alt. the lights stayed the same. I think you will get better brightness by changing the bulbs vs changing to a higher amp alternator. If your lights get brighter with more rpm then you have a charging problem or battery problem.
Old Mar 18, 2008 | 03:02 PM
wombvette's Avatar
wombvette
A higher amp alternator will not brighten the lights, unless the old one is not capable of keeping up. The lights will draw only what they need from the 12V source. Sort of like dipping a gallon of water from an acre pond. Its the same as from a 1000 acre pond.
To 100 Amp Alternator
Old Mar 19, 2008 | 10:04 AM
gingerbreadman1977
im just talking from experience. i had the stock alt in my 81 and i had thermo fans, stereo and ac. i found my dash lights a bit dim and thermo fan a bit on the sad side. i replaced the alt with a bosch constant a year ago and havent had a problem ever since. my lights are bright, my fan is strong.
Old Mar 19, 2008 | 11:22 AM
no2pencel's Avatar
no2pencel
I have a 100 amp Powermaster that works great for my twin Spal fans and A/C. Everything works great at idle. The Alternator never drops below 13.6 volts with EVERYTHING on.
Old Mar 19, 2008 | 01:32 PM
A8skyhawk's Avatar
A8skyhawk
I also think gingerbreadman1977 probably needs the mood lights too....
