I took the rear end out this weekend, I noticed a missing spring bolt, and the isolators between the leafs are looking a little beat! The spring is a 9 leaf, looks ok? Do the composite make a difference? Can I fix the other spring?
Regarding composite springs, I notice there are different "weights" (315 lb, 355 lb, etc etc). What do those numbers mean? I have heard horror stories and seen some end results of the a$$ end sticking up after converting to composite springs AND if they try to adjust it down, "the adjusting bolt is too close to the concrete"????
The numbers are the spring rate. The problem is the arch, not the rating. Just get a proper spring with not too much arch. A composite spring has a much longer lifespan than a steel one and no inter-leaf friction. It can go through millions of full bump to full droop cycles. The steel one will eventually break a leaf in the several hundred thousand cycles region.
Bottom line, the composite spring is far superior to the steel one. The fact that some springs are sold with such an arch that they raise the car too much has nothing to do with the concept of a composite spring but of the spring design itself.
The numbers are the spring rate. The problem is the arch, not the rating. Just get a proper spring with not too much arch. A composite sprig has a much longer lifespan than a steel one and no inter-leaf friction. It can go through millions of full bump to full droop cycles. The steel one will eventually break a leaf in the several hundred thousand cycles region.
Apples to apples, the composite is better than leaf. However, the 'feel' is different and I have heard just as many complaints about composite springs, as I have heard praise.
In reality, the leaf spring would last you another 20 years so it comes down to preference, weight, feel...and what you're looking for out of your rear spring.
I don't mean to be cutting in on this thread, but since we're on the subject of rear springs, I thought this discussion would be appropriate.
So how do you determine what is the right arch? Am I to understand the number of the spring the stiffness? Which (arch, number, whatever) composite spring would you get to 1) get the stock ride height back? 2) have better handling.
My steel spring are OK and I have no issues with them....for now...but I see replacing them within a year and was considering the composite spring.
There's no number for the arch, just stay away from the springs that have been reported to have too much and give a too high settled height (trw).
The hyperco/hypercoils (a quality brand!) spring that Van Steel sells has what looks to be a decent arch and it has the same cambered and tapered shape that the original 81-82 springs had. If I was buying a composite spring, that would be it.
The spring and rate is designed off of the 81-82 cars. Same rate as a 9 leaf.We do have higher tate for guys wanting more performance.
what lb spring would you recommend for a 425+ hp 78 that will see some track action. Olivier suggested at least 360 do you agree, and what will that do to ride under street dirving? Thanks Tom
13 years ago, I tookout the old steel and put in a plastic VBP 360 spring, with KYB shocks....last year finally bought the Bill Steins...and it did make a good improvelemt in ride quality...I recommend the Bilsteins...
but any good similar spring will work well, I suspect....
I changed back to the steel for a test one day....waste of time, no freeking way man....plastic is SO FAR SUPERIOR, i'ts no joke....
From my trials and errors, I believe the most important aspect of getting a composite spring to ride good is the shocks.
- KYB's were way too stiff, just felt really choppy to me
- Bilstein Extremes were too stiff also
- KYB2's had a very good ride, but were too soft for track use
- Edelbrock's are my favorite so far. Nice but firm ride on the street, and work well at the track too (HPDE's, nothing serious)
