Electric Choke
Old Mar 17, 2008 | 10:59 PM
doug9208's Avatar
doug9208
Default Electric Choke
I had my original Qjet rebuilt. I also had the vac. choke converted to electric. the Qjet service manual says the E4ME gets current to the choke coil through the oil pressure switch. No problem splicing a wire from the oil pressure switch but I do not see a place on the choke or carb to connect the wire. any ideas??
Old Mar 18, 2008 | 02:51 AM
tommyleea's Avatar
tommyleea
Normally, the electric choke will have a couple of spade terminals coming off it. Any pictures?
Tommy
Old Mar 18, 2008 | 05:57 AM
Yeller81USNRet's Avatar
Yeller81USNRet
My 81 has a connector to hook up to on the choke
Old Mar 18, 2008 | 10:09 AM
doug9208's Avatar
doug9208
Tommy
now you're making me wonder if they converted the choke. I'll send photos if I can figure out how to upload them.
Old Mar 18, 2008 | 10:24 AM
tommyleea's Avatar
tommyleea
Do you still have the heat tubes and vacuum line connected to the choke housing? I thing the heated/vacuum choke works pretty good.
Tommy
Old Mar 18, 2008 | 10:26 AM
jnb5101's Avatar
jnb5101
not all q-jets can be adapted to electric chokes.
jeff
To Electric Choke
